H22a into 94 coupe injectors wont fire
i bought my 94 accord coupe with the h22a4 already swapped into it. after months of hard driving it threw a rod. i decided to swap in a h22a instead of rebuilding the current motor. after the swap i cannot get the injectors to oopen. i know the injectors are good.
heres everything i know:
-using obd1 dizzy
-have spark
-have fuel coming to the rail and good fuel pressure
-good compression
-timing is dead on
-all grounds are good and i checked the pins on the ecu with a test light to make sure.
ive been reading on some forums here and everyone says there is supposed to be a ground on the thermostat. i only have grounds on the tranny, battery to chassis, and on the driver side mount to chassis. all those grounds are good. the only problem is the injectors will not pulse.
please help me with this!!!!!!!
-using obd1 dizzy
-have spark
-good compression
-timing is dead on
just a little update. i checked for power at the positive prongs on the injector clips and its not nothing. im curious on where the positive injector wires run to?? i could possibly just rewire them??
Jackzor
Apr 22, 2013 04:49 AM
se93
Feb 19, 2002 08:36 AM
