Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Pulled fuse leads to Check Engine Light
Old Oct 23, 2012 | 10:56 AM
Cdeese910's Avatar
Default Pulled fuse leads to Check Engine Light
A couple days ago I accidently pulled the IG ACG fuse without knowing, then drove the car for two days before realizing I had pulled the wrong fuse. Instantly I had a code, P0135 and P0155. I put the fuse back in, tried to clear the codes with a code reader, and it would turn off, then right back on. I even tried disconnecting the battery for some time, and still the light remains on. Will the light eventually turn off, or will the codes have to be fixed? Please help! Out of ideas with what to do. It's a 2004 Honda Accord EX V6 A/T
Old Oct 25, 2012 | 07:43 AM
ntextreme3's Avatar
Default Re: Pulled fuse leads to Check Engine Light
p0135 and p0155 i think is heater circuit on one or both of the oxygen sensors. pretty sure those codes were independent of your fuse pulling.. why did you pull the fuse to begin with? If the light isnt going off its because somethings wrong lol I mean why do you want to shut it off? if you reset the codes and it comes back, fix it
Old Oct 25, 2012 | 07:56 AM
1GPlusSH's Avatar
it bothers him
19Honda91Sedan
17
May 10, 2020 01:20 PM
Offspring EK
10
Feb 1, 2012 06:59 AM
62maxx
Oct 25, 2006 03:45 PM
