FULL PART OUT 01 Black GSR - Motor, Interior, Suspension etc etc
parting out this 01 gsr. Car had jdm front end. Fenders are still good but rest is toast. Strong running Gsr swap. KYB struts with tein springs, Volk gram light rims in 17's, black gsr leather in fair shape.
Car had 103k miles.
Long block 2000.00
Transmission 700.00
Dc Header 150.00
Kyb Struts with springs 300
axles compkete 150
engine harness 200
black carpet 100
Ignition lock set with 2 keys 125
Dash 100
Door panels 125
Center console arm rest 75
Cat converter 75
02 sensors 45 each
Abs sensors 30 shipped each
Front hubs 200 for the pair, complete
Ecu 120
Anything else, let me know. Car is completely dismantled and I have pics for everything.
Car had 103k miles.
Long block 2000.00
Transmission 700.00
Dc Header 150.00
axles compkete 150
engine harness 200
black carpet 100
Dash 100
Door panels 125
Cat converter 75
02 sensors 45 each
Ecu 120
Brake master cylinder and proportioning valve? Also need the 2 transmission to block braces located next to the oil pan if you're willing to part. Send me a pm.
Have the passanger tail light still? And also the cover for the passanger inner mirror the little black triangle shaped cover. And also the inner fenders....would like prices on all and shipping to 95953
sold:
dip stick
axles
power steering tank
header
climatge control
hood release lever/cable
pass torque mount
driver torque mount
header bolts
starter
door speaker covers
pass window regulator
power steering pump bracket
vss
dip stick
axles
power steering tank
header
climatge control
pass torque mount
driver torque mount
header bolts
starter
door speaker covers
vss
SOLD :
jack
egnine harness
charcoal canistrer
driver rear seat belt
radiator overflow reservoir
oh **** handle
rear view mirror
driver heater vent
driver motor mount
rear sway bar
map light
pass rear abs sensor
prop valve
jack
egnine harness
charcoal canistrer
oh **** handle
rear view mirror
driver heater vent
driver motor mount
rear sway bar
map light
prop valve
SOLD :
Transmission
Steering wheel
ecu
passenger door handle cover
passenger mirror
fuel pump
tire jack
Transmission
Steering wheel
ecu
passenger mirror
fuel pump
tire jack
Car had 103k miles.
Long block 2000.00
Transmission 700.00
Dc Header 150.00
axles compkete 150
engine harness 200
black carpet 100
Dash 100
Door panels 125
Cat converter 75
02 sensors 45 each
Ecu 120
Car had 103k miles.
Long block 2000.00
Transmission 700.00
Dc Header 150.00
axles compkete 150
engine harness 200
black carpet 100
Dash 100
Door panels 125
Cat converter 75
02 sensors 45 each
Ecu 120
