S2k Cluster in ek? question
Old Oct 23, 2012 | 09:26 AM
ThaiRacer's Avatar
Default S2k Cluster in ek? question
Ok i been researching left and right, most of the threads are old and outdated. I read where its possible to install the S2k cluster in the ek without speedohealer and modifry. Is this true? If so how do i go about doing this?
Old Oct 23, 2012 | 01:34 PM
jdmadam's Avatar
Default Re: S2k Cluster in ek? question
I used a speedohealer and I used an aftermarket gauge for water temp. There were a couple guys that used a custom box to convert the speedo signal and there is this guy --->http://www.marklamond.co.uk/products/s2000/s2000.htm --- who I think does it all internally within the cluster to make it plug and play. But the easiest way is to use the speedohealer and modifry unit. You are also gonna need a potentiometer for the gas signal which cost about $2 at radioshack. The S2k swap cluster threads are not outdated, there is still plenty of useful information in those threads.
Old Oct 24, 2012 | 06:28 AM
ThaiRacer's Avatar
can u give me the links that arent outdated? everything i found is like from o9 and down
Old Oct 24, 2012 | 09:59 AM
jdmadam's Avatar
That's the thing, some of the threads are from 09 and down but that does not mean that they are outdated. There is still a lot of useful info in those threads that a lot of people still use today.
Some of the threads I found useful were these:
https://honda-tech.com/forums/hybrid-engine-swaps-18/s2000-cluster-swap-wiring-guide-1570344/
http://marketplace.honda-tech.com/sh....php?t=2148453
Read through these threads and you will find good info.
Old Oct 24, 2012 | 03:47 PM
98.4DR.EK.D16's Avatar
bump so that i can find marks link later lol so just to be sure i read correctly, mark sets it up so that its plug n play with the ek plugs?
Old Oct 24, 2012 | 05:04 PM
jdmadam's Avatar
He makes it plug and play to a certain extent. You still would have to cut and splice to mate it to your stock harness which is simple as hooking up a car stereo.
shmooly
12
Dec 1, 2015 05:52 PM
v8killaz
Sep 25, 2010 10:21 AM
alispoon
Nov 10, 2005 03:24 PM
ah789454
Nov 8, 2004 08:28 PM
