d16y8 intake manifold to a d15b7 head
Old Oct 23, 2012 | 07:25 AM
[713]'s Avatar
Default d16y8 intake manifold to a d15b7 head
have a vacuum leak and idle problems with the manifold on the head, i figured out that i need to replace the gasket for it, but i need some clarification on to what i can use as a replacement because im not sure what i need to get. also the car has been idling strange, but i managed to get some of it worked out, but idk since the gasket needs replacing that might be whats throwing it off, but i know that after driving it around yesterday, i cant take steep hills because the car wants to die from giving it gas to get over, any insight to that? i think thats all i can think of for now so any input is appreciated
Old Oct 23, 2012 | 09:02 AM
EFinAwesome's Avatar
Default Re: d16y8 intake manifold to a d15b7 head
be 100% sure to rid yourself of vac leaks and get the new gasket. That should fix what sounds like a air/fuel problem. If not post back with some more details.
Old Oct 24, 2012 | 05:29 AM
[713]'s Avatar
ok cool, ill try to get some pictures up of my setup so there can a visual of how i did my lines, also you wouldn't happen to know which gasket should i get? a b7 one or the y8 one?
Vtec04
Honda Civic (2001 - 2005)
16
Jun 5, 2017 07:44 PM
qpzm12
Oct 4, 2010 03:19 PM
HCivExoo
Sep 26, 2005 06:05 AM
