Does this look like a Delta Camshaft 272 Re-grind to you?
Old Oct 22, 2012 | 06:11 PM
Boosted_90Teg's Avatar
Default Does this look like a Delta Camshaft 272 Re-grind to you?
I just got these back today, and I have to say, I'm a bit unimpressed. I've seen many pictures and videos of other camshafts, and they looked amazing. So what is this?!
Sorry for the image size, but I'm super confused. I was told all the lobes would be re-done, but it only appears as if the primary vtec lobe was touched. Where's the surface treatment, where's the polishing?
Thoughts? I already sent them an e-mail, so I'm just waiting to hear back.
Old Oct 22, 2012 | 06:36 PM
PhilStubbs's Avatar
Default Re: Does this look like a Delta Camshaft 272 Re-grind to you?
that looks nothing like my 272-2 looked when i got it back. i know they did mine cause i measured it against an untouched stock cam. kinda looks like nothing was done from the pics
Old Oct 22, 2012 | 06:38 PM
Well Jon e-mailed me back and explained some things in greater detail. Plus after checking them out some, the scrapes aren't because no work was done, it's from the graphite coating on the cams rubbing off in the box. I also looked at an image of a stock B16A2 cam, and these have been re-done.
So now all I need to do is install them, put my new chip in my ECU, set valve lash, and see what happens.
Kamikaze
Aug 28, 2007 09:27 AM
highperboi
95
Nov 30, 2005 03:26 AM
dinko
Welding / Fabrication
Dec 24, 2004 02:28 PM
eh6
Sep 16, 2004 11:12 PM
^MikeG
Apr 23, 2004 10:30 AM
