92 lude h23 to h22 swap issues!?!?
Old Oct 22, 2012 | 01:40 PM
95EJ1GSR's Avatar
Default 92 lude h23 to h22 swap issues!?!?
Doing a job for a customer: 1992 prelude with h23 swap. He threw a rod and wanted a h22a swap put in it. Got the long block and put it all in. Using the h23 harness and Trans. My questions are map sensor? Use one on fire wall or tb? No spark at all. I am running the h23 dizzy and external coil. No spark. I just need guidance and help. It's frustrating me badly. Please help guys. I just want it running and out my yard so I can get paid lol
Old Oct 22, 2012 | 02:04 PM
snobordboy's Avatar
Moderator
Default Re: 92 lude h23 to h22 swap issues!?!?
It probably had MAP on firewall, so I would use that.
Are the grounds good, specifically tranny and the one by the VTEC solenoid?
Old Oct 22, 2012 | 02:24 PM
95EJ1GSR's Avatar
Ok on the map and the grounds are great. So lost
Old Oct 22, 2012 | 02:28 PM
yroachy's Avatar
Agreed, I did the exact same swap in my 92. I ran vtec solenoid and pressure switch wires to p13 ECU, H23 TB and map sensor (tps sensor broken on my h22). Started up right away.
As far as your no spark... Are you sure it's an h22a and not an a4? The a4 has the crank sensor on the crank timing gear instead of in the dizzy like the h23...
Old Oct 22, 2012 | 02:36 PM
95EJ1GSR's Avatar
It's a 95 h22a. No crank sensor by pulley. How did u run the external coil
Old Oct 22, 2012 | 02:50 PM
yroachy's Avatar
The 92 h23 harness has the plug for the external coil already there. I used the jdm, dizzy on my swap so i had to jump the connector to provide power to the internal coil. I would have used the h23 dizzy with external coil had it not been throwing a code before I did the swap.
Have you checked your ecu/radio fuse and ground?
Old Oct 22, 2012 | 03:04 PM
95EJ1GSR's Avatar
Where is the ecu/radio fuse and ground? The radio works....
Old Oct 22, 2012 | 03:32 PM
yroachy's Avatar
Under hood fuse panel. What ecu are you running?
Old Oct 22, 2012 | 03:39 PM
95EJ1GSR's Avatar
Fuse and p13 and I tried the p14 and still nothing. Would the ecu stop it from spark
Old Oct 22, 2012 | 03:51 PM
yroachy's Avatar
See if you have crank an cam sensor signal going to the ecu. And double check your dizzy connections.
Old Oct 22, 2012 | 03:53 PM
yroachy's Avatar
Also check the icm output to the coil.
Old Oct 23, 2012 | 12:29 AM
1funryd's Avatar
You did not specify if this was a H23vtec Bluetop or just an H23a/a1 nonvtec motor.
Old Oct 23, 2012 | 05:09 AM
95EJ1GSR's Avatar
H23 non vtec
Old Oct 24, 2012 | 02:28 AM
95EJ1GSR's Avatar
Bump
Old Oct 24, 2012 | 11:37 AM
yroachy's Avatar
Is everything I suggested checking good?
Old Oct 25, 2012 | 10:10 AM
95EJ1GSR's Avatar
How do I test the coil
Old Oct 25, 2012 | 11:06 AM
yroachy's Avatar
Back probe the thin blue wire at the coil connector and use a test light while cranking.
Old Oct 25, 2012 | 12:01 PM
95EJ1GSR's Avatar
Do u have a number I can call u
Old Oct 25, 2012 | 01:19 PM
Apex1972's Avatar
and you are a mechanic professionally or a shadetree mechanic?
Old Oct 25, 2012 | 04:49 PM
95EJ1GSR's Avatar
I have a degree in automotive tech and yes I didn't know how to test the coil. Are u here to help me figure this problem out or judge me?!?
Old Oct 25, 2012 | 09:14 PM
1funryd's Avatar
Did you test the coil?
Old Oct 26, 2012 | 06:12 AM
95EJ1GSR's Avatar
Yes good
Old Oct 26, 2012 | 11:48 AM
yroachy's Avatar
Is it getting the trigger signal on the thin blur wire or did you just ohm it out?
Old Oct 26, 2012 | 01:35 PM
95EJ1GSR's Avatar
Ohm it out
Old Oct 26, 2012 | 02:33 PM
yroachy's Avatar
Test to see if it is getting the trigger signal on the blue wire at the coil connector. If not your problem is ecu, dizzy, or wiring harness. If it is getting the trigger signal the your problem is cap rotor wires plugs or coil.
