Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help identifying motor and trans
Old Oct 22, 2012 | 12:54 PM
KYLE_22's Avatar
Default Help identifying motor and trans
I am new to these civics and trying to learn how to identify these parts. All I have been able to come up with thus far is that the motor is a 1.7L, however I'm not sure on specifics or how many varieties of 1.7L's there are.
Vin # is 1HGEM21592L071071
Also, once I can learn what this transaxle is, could someone direct me to good reference material for tear down and rebuilding?
Old Oct 22, 2012 | 09:24 PM
grjr's Avatar
Default Re: Help identifying motor and trans
engine looks like a D17A1, not familiar with the model # for the transmission.
imo that generation of civic has various problems and aren't very friendly to work on :-/
Old Oct 22, 2012 | 09:34 PM
KYLE_22's Avatar
Would you mind elaborating on the problems? And whether or not they are performances based because this is being kept stock for daily driving use only
Old Oct 22, 2012 | 09:41 PM
It Wasn't Me's Avatar
The engine:
It's a D17A1 non-VTEC engine from a 2002 Civic LX coupe manufactured in Ohio. (should be stamped on the block just above the clutch slave cylinder)
The transmission:
It's an SLW 5-speed manual. (should be marked on the transmission, but it may be difficult to see with all the grime on that thing)
As far as reference material for a rebuild, I recommend buying a Helm's manual published by Honda Motor Co. Click here and get the first one. (61S5C01)
The most common problems are head gasket failure and the main input shaft bearing "hissing." Since you're rebuilding the transmission anyway, I wouldn't worry too much about the bearings. (assuming you're going to replace them.)
The automatic transmissions are notoriously known for premature failure also, but since your car is a manual, there's nothing to worry about as far as that is concerned.
Old Oct 23, 2012 | 04:24 AM
KYLE_22's Avatar
I want to hump your leg for all that great information!
I got lucky with the manual, a family friend is a mechanic and is letting me use his computer with all the manufacturers shop manuals
jamesthayer21
Honda Civic (2001 - 2005)
May 5, 2018 07:31 AM
93sihatchy
May 29, 2007 01:35 PM
matt87
Feb 16, 2005 09:43 AM
