88crx si trailing arms?
Old Oct 17, 2002 | 07:36 PM
shortyz's Avatar
Default 88crx si trailing arms?
ok are these good trailing arms. i have heard the ITR trailing arms were moldeled after these.
also they are drums can u swap on some disc's and calipers?
Old Oct 17, 2002 | 07:51 PM
Mugen Dom's Avatar
Default Re: 88crx si trailing arms? (shortyz)
trailing arms are the same from 88-2000 the brakes attached are diff though....now the control arms are diff from 88 which all japanese and european cars also came with from 88-2000 even the base models in japan just have a eye mount shock in the rear
Old Oct 17, 2002 | 08:59 PM
shortyz's Avatar
there isnt any diff in trailing arms from 88-2000?
odd..
so basically they arent gonna do me any good over my stock ones?
Old Oct 17, 2002 | 10:16 PM
jasonb's Avatar
Default Re: 88crx si trailing arms? (JdMB16Ahatch)
The trailing arms arent all the same. For example, I have a set of 88 CRX Si arms and they are different than the set of 90 Teg LS arms I have. The Teg trailing arm bushings are quite a bit bigger than the CRX bushings. This may or may not have an impact on the handling/ride of the car, but it regardless it still is a difference.
Old Oct 17, 2002 | 10:22 PM
spettinger's Avatar
Default Re: 88crx si trailing arms? (jasonb)
i noticed my rear track is definitely wider after putting 90 ls trailing arms in place of my stock 89 CRX SI's. i still want to know if it is possible just to put on some hubs and disc brakes onto a drum style arm. oh well, have disc brakes, don't need to worry about that anymore. oh, by the way, anyone have some extra 90-91 crx ebrake cables around?
Old Oct 18, 2002 | 07:52 AM
Mugen Dom's Avatar
Default Re: 88crx si trailing arms? (wreckedhatch)
from what mugenef7 showed me there is a big *** bolt in the back of the trailing arm holding the brakes on u can take a crx si rar disc and slap it on....the trailing arm design is the same 88-2k u can bolt any of them onto the 88civic...i have 93 teg rear arms and the track as u call it is maybe a cm wider if that....i have barely any camber with them and they clear the fenders so its no problem
Old Oct 18, 2002 | 10:02 AM
spettinger's Avatar
i don't clear my fenders because i have the wrong tires on the back 205 55 15's muddin tires for a honda! need some 195 50's.
Old Oct 18, 2002 | 10:32 AM
FourthGenHatch's Avatar
Even if you could swap out just the disc part for the drum you would still need to get new ebrake cables and that is the bitch part of the swap. So might as well just get the whole trailing arm.
wickedEFguy
Jun 23, 2009 03:07 PM
ED9man
21
Jun 7, 2006 05:07 PM
sackdz
Mar 19, 2005 10:06 AM
singlecamcrx
Nov 28, 2004 01:45 AM
Fishcat37
11
Apr 9, 2003 11:16 PM
