CT FS: 2006 Evo IX MR SE - very built w/ 5 speed conversion
Old Oct 22, 2012 | 08:39 AM
CTGrey06RSX-S's Avatar
Default FS: 2006 Evo IX MR SE - very built w/ 5 speed conversion
This is one of the cleanest evos you will find with nothing but the best parts, no shortcuts, and a true beauty. Everything I have done to this car has been carefully chosen and well taken care of. The car has approximately 45k miles on it, with about 3k easy street miles on the engine. With this setup, the car has the potential to make 700whp on race gas. Currently the car is being driven on a conservative 25psi, 93oct tune and runs like a rocket ship. Several receipts in hand! This car is easily worth one and a half times what I'm asking for it, and is one of the cleanest cars on the road. Garaged year-round and not driven in the winter.
*2006 Mitsubishi Evolution IX MR SE* $26,500
VIN: JA3AH86C66U065920
Engine:
Buschur 2.1L - 10:1 compression short-block.
New OEM Mitsubishi oil pan.
New OEM Mitsubishi windage tray.
New OEM Mitsubishi modified 2.1L water pump.
New OEM Mitsubishi timing belt tensioner.
New Gates Racing Kevlar timing belt.
New OEM Mitsubishi oil pump.
Buschur balance shaft eliminator kit.
Buschur stainless MIVEC oil line.
Ported & polished head.
Stainless o-ringed head.
ARP L19 head-studs.
Buschur 2.1L machined OEM Mitsubishi head gasket.
Supertech bronze valve guides.
Supertech std. size valves.
Supertech dual springs / titanium retainers.
GSC S2 camshafts.
Kiggly HLA.
Topline lifters.
New OEM Mitsubishi gasket set for engine build.
Torque Solutions 3-piece motor/tranny mount set.
Drivetrain:
5-speed conversion.
Bushwacker 5-speed transmission.
Buschur short-throw shifter.
Exedy triple disk clutch.
STM clutch fork stop.
Momo GTR2 shift ****.
Torque Solutions shifter base bushings.
Torque Solutions shifter cable bushings.
Intake / Exhaust / Turbo / Fuel:
HTA 3582R turbo + new oil/coolant lines.
Buschur T3 cast manifold.
Tial 44mm wastegate with external dump.
STM 4" intake with large K&N filter.
AMS Front Mount Intercooler.
Tial blow off valve.
Buschur 3" upper intercooler pipe.
Custom lower intercooler piping.
Walbro 400lph fuel pump.
PTE 1200cc injectors.
Buschur 3" cat-back exhaust
Meagan 3" down-pipe.
3" test-pipe w/ cat shrouding.
Tuning / Electronics / Other:
JMF mini-battery kit.
Hallman Pro manual boost controller.
OMNI 4-bar MAP sensor.
GM IAT sensor.
SpoolinUp MAF to IAT harness.
Defi boost gauge.
Defi oil pressure gauge.
Defi EGT gauge.
AEM UEGO wide-band and gauge.
OEM Mitsubishi Evolution MR Metric boost gauge.
OEM Mitsubishi Evolution MR Voltage gauge.
Blitz turbo timer.
Mishimoto silicone upper radiator hose.
Mishimoto silicone lower radiator hose.
Slim radiator fan.
Polished exhaust manifold heat shield.
Interior / Exterior / Suspension:
Stock MR Bilstein struts.
Swift Spec-R springs.
Red-stiched Recaro seats (Evo SE)
Volk TE 37 Superlap wheels with Nitto NT555 tires.
JDM yellow fog lights with factory xenon headlights.
Big thanks to MIKEY PHOTOGRAPHY for some of the pics!
There will be no taking the car out to joy ride or beat on it, no dead-beat buyers - only serious inquiries please, no trades either. Thank you.
Old Oct 22, 2012 | 12:58 PM
Bsixteen_CRX's Avatar
Default Re: FS: 2006 Evo IX MR SE - very built w/ 5 speed conversion
Bump for a sick a$$ evo.
Old Oct 23, 2012 | 04:23 AM
Thanks!
excessive
Oct 17, 2011 04:14 PM
Globe1896
Sep 17, 2009 10:12 AM
r1de23
Jul 15, 2009 06:30 PM
r1de23
Jun 30, 2009 07:35 PM
hybrid1990crx
Sep 19, 2006 04:52 PM
