cheap c.o.p chasebay harness
Price
$1250 for all
only trade is wanting trade for rywire OBD1 tucked harness, obd1 injectors, obd1 alt, obd1 dizzy with aftermarket wires, hondata s300 ecu
Contact information
punk_5k8r@hotmail
Is the item new or used
Used
Product description
i bought this used
some clips had came broken which i fix
one ecu came in broken that i couldnt fix
i pinned it manually
previuous owner had it running in his gsr hatch
i went to OBD2 to run this harness
plans changed and will be going back to OBD1
HOWEVER:
once installed im my car
i could only get the car to running one time
im not sure if its any of the AEM parts or the actual harness or ecu plug
could also be that it needed to be calibrate
i never plug the ecu to read it
b/c i dont own a microsoft computer
could be an easy fixed
this is a good deal if your good with wiring
ALSO some of the wiring got burnt but was fixed
INCLUDES:
no part out unless i get interest on a couple parts
i also have the sub harness
that goes from odb2 harness to the chassis obd1
$60
AEM EMS 30-1020
-aem modded for c.o.p.
$650 obo -
AEM EPM
-Engine Position Module
(required for c.o.p.)
$280 obo -
Chasebays Harness
-made for B series with c.o.p.
-can disconnect c.o.p. harness and connect a standard distributer harness
$415 obo -
OEM Honda Coil Packs
-used 800 miles
-rsx/s2000 (or B series c.o.p.)
$80 obo -
Rywire Coil Pack Fastener
-used for B series valve cover with c.o.p.
$70 obo -
i had it also polsihed by CNS
OBD2 Alt and OBD2 Starter $120
burnt sections
fixed:
then wrapped with black electrical tape
damage of the ecu plugs
all i did was pin it myself
(half pictures of the order)
only 3 wires
black/green
white/green
yellow
will get more pics once removed from the car
also has OBD2 Injectors: $40
may lower the price a bit if your car is already OBD2 since you wont be needing the OEM parts
here some pics:
complete
the ecu plugs
wires on the top right hand corner
are loose wires that i had to manually pin
this was the burnt section
has not been re-loom just electrical taped
if needed:
$1250 for all
Contact information
punk_5k8r@hotmail
Used
Product description
i bought this used
HOWEVER:
INCLUDES:
$60
AEM EMS 30-1020
$650 obo -
AEM EPM
$280 obo -
Chasebays Harness
$415 obo -
-used 800 miles
$80 obo -
$70 obo -
burnt sections
fixed:
only 3 wires
black/green
white/green
yellow
here some pics:
complete
the ecu plugs
if needed:
DomkeBoy
Aug 10, 2012 07:58 PM
