accord v6 trans swap .. help!!
Old Oct 21, 2012 | 02:29 PM
WHOIZDIZGUY's Avatar
Default accord v6 trans swap .. help!!
10/22/2012
how much fluid do i pore into the EMPTY TORQUE CONVERTER BEFORE installing a trans
10/21/2012
well
I've been searching for a few days
n just gave up n know ill get a quick respond on here
I swapped out a 99 v6 transmission
ni put 2 qrts in the torque converter
added 6qrts into the tranns
n when i give the car gas .. it takes a while for it to actually take off
i have to give it a lot of gas
i called up someone from honda n he said to add 4 more qrts
it moved slightly better after
i check the dip stick [ _-_-_____________}___-]
thats my ghetto drawing of the dip stick
the [ is the begining and the ] is the end of the dipstick
the } is where the fluid is
the - is the dots on the dip stick
thrs 2 dots at the bottom of the dipstick and one dot at the end
that seems to be way to much to me
i googled it n saw someone saying he put 8qrts staight into the T.Q.
but didnt say how much he put in the trans
how do i get the T.C. to fill quickly
i let the car run while in park
also left the car in drive in the air
both for an hour
n it still has not dropped down on the dipstick
any suggestions
u can call me or text 212 3808337
pm me
reply
anything helps
thank u H-T
Old Oct 21, 2012 | 02:30 PM
Default Re: accord v6 trans swap .. help!!
AUTOMATIC !!
Old Oct 21, 2012 | 02:37 PM
jdowen2's Avatar
fluid capacity is 7.6 quarts. You're overfilled.
Old Oct 21, 2012 | 02:54 PM
N I FORGOT TO SAY I DRAINED OUT THE TRANS AND T.C. BEFORE I INSTALLED IT
I DONT MIND DUMPING OUT THE FLUID IF SO
Old Oct 22, 2012 | 06:25 AM
10/22/2012
NorskJohnny
Jul 28, 2016 02:02 PM
BDB_LV
Apr 5, 2013 05:43 AM
gmin
May 14, 2011 07:05 PM
Golferdude1977
Jan 16, 2011 07:46 PM
Jer510
Sep 29, 2010 09:15 AM
