Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2006 accord wont start when previously driven. losing my mind and temper
Old Oct 21, 2012 | 01:12 PM
BennyG79's Avatar
Default 2006 accord wont start when previously driven. losing my mind and temper
My 2006 2.2 diesel accord has trouble starting if warm after being driven. If I simply go to the shops, it will start from cold outside my house, but after stopping & getting the messages or whatever, it wont start again. i often have to push start it to get home. i brought it to the garage who did a dianostic exam. they said the injectors need replacing. i got this done with a mechanic friend but it made no difference. i also replaced the high pressure pump....no difference. i replaced the diesel filters. no difference. we also installed a non-return valve on the diesel line so the pressure remained...still no difference. im nearing breaking point with this car. one strange thing is that after each of the different components were removed and replaced, it started fine each time afterwards for about 2 days but then the same old problem returned. please please can someone give me help on this one?????? PLEASE
brendan
Old Oct 21, 2012 | 02:27 PM
Crashmaster's Avatar
Default Re: 2006 accord wont start when previously driven. losing my mind and temper
Did someone just replace the injectors or test them first? Is there any excessive smoke out the exhaust? I do remember seeing some diesel Accords with injection pump problems. Also remember special air bleeding techniques when replacing the filters.
Yes, owning a diesel Accord can give you bragging rights when it runs good, but when it doesn’t, you must go through replacing parts to try and find the problem. I would suggest that you take the vehicle to a shop that specializes in diesel cars. It might not be the Honda dealership.
bwk
Dec 29, 2017 04:49 PM
Snuffy's Accord
Mar 12, 2014 06:45 PM
luohaoran
Oct 2, 2010 04:12 AM
