this was in my trunk when i traded my car....'pics'
am i wrong or is this my rear sway bar and is this why my is sagging like a dirty ***** and if its am i missing anything or is everything there
From: Pensacola, FL and every Court House in Louisiana
I assume this is for your 92 civic 4dr ex chassis. Yes that would be the rear sway bar but would not be the reason the rear is sagging. What kind of strut and spring set up do you have? I would guess old worn out spring possibly bushings would be the culprit
everything was stated , my topic says this was in my trunk. second im asking is this my rear sway bar. 3rd is this important should i put it back on asap. 4th is everything there or should i just junk it
Yes, you should put it on! it's not a life or death, but definetly put it on it.
Is it all there? does the left bushing have a d- bracket?
other then that, do you have the brackets on your subframe? If you do, you need bolts. which will be cheap.
am i missing alot of the hardware or is it all there, im curious to know . obviously my rear lower control arms are there, but this sway bar was in my trunk,
If you car is sagging, you might check to see if the previous owner cut the springs. Anyone who would remove the sway bar might take a hack saw to the springs.
i was looking under the back of my car and. i see the rear sway bar, so does this mean
this sway bar i have with me was for the front of my car im confused
it looks like the rear sway bars theres, so now im convinced that the front sway bar isn't on the car, maybe thats why im having so much play in my wheel....
car has lowering springs in back, but i already knew that the front are no name brand adjustables and kyb struts...but thats not my complaint, the only thing bothering me is the play in the steering wheel that im having..its horriable i was going maybe 45-50 maybe a slight turn and the car jerked it self like it had extra play.....i dont like that ****
i did a little research, the reason why my tire has a little play when jack up isnt because of wheel bearing or tie rod. because of my driver side ball joint. so thank god its not my rack&pinion
yea thank god, . and did you read what i put its not the rack & pinion thats causing my wheel to have play its the lower ball joint, the guy who said it was my rack & pinion didnt fully have the car lifted up he just wiggeld the tire and shined his flash light said look your rack&pinion and showed me this little ball having play near the axle trip out....im glad its not my rack though arent they exspensive?
yea, well thanks man for your help here, i can tell you have patience for my lack of knowledge on cars and i appreciate it, not like some people on this forum . Ill keep you posted on my car
also i figured that my cars running rich because i dont see no smoke and it stinks like burnt charcol witch lead to my though of the car not being tuned i mean it cant be tuned obviously if vtec isnt even connected (no vtec wire harness) ...so this car isnt running to its full potential...
this week ill be replacing motor mounts,lower ball joints
and start saving up for a tune...then full suspension.
deviant1
10
Aug 24, 2004 05:43 AM
