Thinking about using this ITR crank in a rebuild ?
Old Oct 20, 2012 | 03:27 PM
EF9_TryMe's Avatar
Default Thinking about using this ITR crank in a rebuild ?
I have a ITR Crankshaft that has a worn out #1 Rod Journal, and want to know if it is
still in good condition for repair. I have printed out the rod journal measurements for a review.
Unfortunately my micrometer doesn't measure in .0001 :/
So this Harbor and "Fragile" instrument will have to do for right now.
Pictures of the Crankshaft, and Damaged Rod Journal.
Bad Rod Journal
The Rod Journal Measurements.
Inspect #1 Rod Journal oval shape journal.
Old Oct 20, 2012 | 03:49 PM
97mm_EH3's Avatar
Default Re: Thinking about using this ITR crank in a rebuild ?
Well, the crank has already been turnred once, as standard is 1.771 in. you would have to go .020 under. How are the mains? Is the crank straight?
I would not use it.
Old Oct 20, 2012 | 11:50 PM
EF9_TryMe's Avatar
So the crank is Garbage ?
A machine shop wouldn't be able to fix this ? Not sure if the crank is straight. The main
Journals look good. I definitely was not going to use it in the current condition.
Actually have the readings right here!
Old Oct 21, 2012 | 05:47 AM
EG1834's Avatar
A crank grinder could fix it easy.
Old Oct 21, 2012 | 07:34 AM
EF9_TryMe's Avatar
Awesome. All I wanted to know.
Thanks!
Old Oct 21, 2012 | 01:35 PM
EF9_TryMe's Avatar
Hmmm ? Nobody else want to chime in.
I guess the decision will be left for a professional very experienced machinist.
But the breed for these guys is very rare now a days! >_<
Old Oct 21, 2012 | 02:42 PM
UncleD's Avatar
I wouldn't use it personally. Cranks are a dime a dozen. Find one that hasn't had a spun bearing and there ya have it.
Old Oct 22, 2012 | 01:15 PM
EF9_TryMe's Avatar
Dude. The thing is, a good crank now a days is so hard to come by!
I have a feeling the B Series engine will die out soon enough.
Old Oct 22, 2012 | 02:31 PM
UncleD's Avatar
Huh!? I can find crankshafts all day for sale that are good? King Motorsports has a boat-load of them, give em' a call and see how much they want!
Old Oct 23, 2012 | 08:08 AM
EF9_TryMe's Avatar
Never heard of em.'
Will try them. Thanks.
viera
Feb 19, 2010 12:09 PM
redline870
Apr 18, 2009 06:57 PM
eg4life1202
11
Jan 14, 2007 09:17 AM
TRuST
Jan 8, 2007 06:42 PM
hatchedzex
Oct 4, 2004 11:40 AM
