Two aftermarket B16 intake manifold FS
Old Oct 20, 2012 | 12:47 PM
wanabgts1's Avatar
Default Two aftermarket B16 intake manifold FS
I have two intake manifold for sale, they are both Type-r/B16 fitment. The first one is I believe and older Blox type-r replica. Has been port matched for up to a 72mm throttle body, and runners have been smoothed about 4" in toward the plenum. The bolt hole area that usually blocks fuel regulator mounting has been removed. Only problem with the mani is the middle fuel rail bolt hole has a bolt broken off in it. I never used all 3 but im sure it could be removed.
Asking 115shipped.
The second manifold is a Top Speed, I don't think they make them anymore. Its a complete sheet metal manifold, not a cut stock one with a plenum on it. Has good velocity stack in the floor and decent plenum volume. Would make a great turbo manifold but also performed well on my all motor car. Ported for 72mm throttle and has been blended where the runners meet the flange. This manifold has been modified to fit LHD vehicles (plenum had to be slash cut and re-welded. Does had an IAC flange on the manifold, however I used an older d-series one for it to fit correctly.
asking 215shipped! 15 more if you want the IAC that fits.
I will be adding some more stuff as I pull the car apart for a post-season overhaul.
All parts are located in Portland oregon, Paypal accepted if you pay the fees!
Thanks,
Zack
boostek9
Aug 16, 2011 04:25 PM
del_slow420
Aug 15, 2006 04:10 PM
JDMlyfestyle
Oct 21, 2005 01:07 AM
TurbodCX
Aug 1, 2002 03:05 AM
