Prelude problem
Old Oct 20, 2012 | 12:43 PM
menyan's Avatar
Default Prelude problem
This prelude‘s engine has a wired noise, and gives white smoke, dose anyone know what is wrong with it?
Here is the video
http://youtu.be/Hm-ksgYNCIM
Thank you!
Old Oct 21, 2012 | 05:44 AM
Enzo15's Avatar
Default Re: Prelude problem
Does the smoke smell sweet? Does it get worse when you rev it up? Are there bubbles showing up in your radiator? If it does more than likely it is a blown head gasket.
Old Oct 22, 2012 | 11:48 AM
menyan's Avatar
Thank you for your help.
It smells a little bit...I haven't checked the radiator yet. If it is the head gasket, how much it takes to fix that?
Old Oct 23, 2012 | 05:48 AM
Enzo15's Avatar
If you can do the work yourself its gonna take time and parts, and you should have the head milled flat as well as check the block to make sure its flat. To do it yourself it would be probably 3-400 in parts. To have a shop do it, Im thinking it will cost closer to 900 or more. Im not too sure.
DumpdEJ6
14
Jul 17, 2011 07:26 PM
CNSK
Sep 7, 2005 06:33 AM
eazye187
Aug 2, 2005 05:29 PM
92silude
Dec 8, 2004 09:33 AM
speed_racer012
Apr 26, 2003 07:23 PM
