H22 H23 PRELUDE PARTS 1992-2001
Below is a list of the parts, most parts on top are 1997-2001 the 1992-1996 parts are on the bottom, 925-321-5289
1999 PRELUDE SUB FRAME $50
1999 PRELUDE STEERING SHAFT 30K MILES $45
1999 PRELUDE SIR S SPEC STRUT BAR $40
1999 PRELUDE SIR S SPEC RIGHT HAND DRIVE WIRING COMPLETE $50
OIL COOLER KIT COMPLETE MOUNTS TO BUMPER SUPPORT NEW FILTER, RELOCATED YOUR OIL FILTER TO THE FRONT OF THE CAR REMOVED FROM 1999 PRELUDE $150
A/C BOX DASH OUT OF A 30K MILE CLIP NEAR NEW $40
FAN BOX DASH OUT OF A 30K MILE CLIP NEAR NEW $40
HEATER CORE DASH OUT OF A 30K MILE CLIP NEAR NEW $40
SPEED SENSOR 5-SPEED REMOVED FROM 30K JDM H22 $40
E-BRAKE HANDLE JDM 30K MILE LIKE NEW $30
BRAKE BOOSTER OEM HONDA removed from 1999 sir s spec $40
STARTER 1997-2001 5-speed 120K MILE $40
BRAKE FLUID MASTER CYLINDER RESERVOIR HONDA OEM FROM 30K MILE CLIP $30
THROTTLE PEDAL WITH FRAME 30K MILE CLIP $40
POWER STEERING RESERVOIR WITH HOSES REMOVED FROM 1999 PRELUDE $30
AXLES DRIVER AND PASSENGER HALF SHAFT $40 FOR A PASSENGER AXLE $40 FOR A DRIVER SIDE AXLE WITH HALF SHAFT (DAMAGED WHEEL SIDE THREAD) $40
FUEL LINE AND FILTER 1997-2001 $35
CHARCOAL BOX AND LINE $30 OFF A 30K MILE CLIP
INTAKE VACUUM BOX 1997-2001 $30
BATTERY HARNESS AND GROUND 1997-2001 $25
ENGINE HOSES 6 FOR $25
1997-2001 HOOD LATCH $20
FIREWALL ENGINE COOLANT HOSE WITH HEATER VALVE 30K MILE $30
GUTTED CATALYTIC CONVERTER $30
H22A4 HEAD BOLTS WITH WASHERS $30
H22A4 FULL VALVE TRAIN 70K MILES $30
1997-2001 PRELUDE CARPET AND FLOOR MATS $30
1997-2001 ALUMINUM A/C COMPRESSOR ENGINE BRACKET $35
FRONT REAR AND DRIVER SIDE ENGINE BRACKET $30 a piece
ALUMINUM TRANSMISSION/ENGINE BLOCK COVER 1997-2001 $30
GREDDY TURBO BLUE BOX ENGINE MANAGEMENT 1997-2001 PRELUDE $75
1992-1996 PARTS
1992-1996 COMPLETE STOCK INTAKE WITH FENDER RESERVOIR AND DIAPHRAGM $40
NEWER RADIATOR WITH FANS $50
4WS 5-SPEED SI ECU WITH FRAME $40
H23A3 ALTERNATOR BRACKET $30
H23A3 A/C PUMP BRACKET $30
H23A3 HEADER AND DOWNPIPE WITH NEW O2 SENSOR $45
H23A COMPLETE CRUISE CONTROL $20
H22A OEM OIL PUMP WITH PICKUP 40k miles no damage $40
H22a OIL STICK AND TUBE $20
H22A AUTOMATIC TIMING TENSIONER KIT COMPLETE $30
H22A ALTERNATOR BRACKET $25
H22A A/C BRACKET $25
1992-1996 PARTS
customs-25
Aug 18, 2013 04:00 PM
customs-25
Northern California (Sales)
Dec 4, 2012 06:21 PM
customs-25
Oct 4, 2012 07:20 PM
bcbargains
Oct 17, 2005 07:37 AM
