F20B Del Sol Hondata S300 won't go past 3000 rpms while rolling
Like the title says is what I need help with. The car runs fine just that it will not go past 3000 rpms. Was running fine earlier in the day and then started having that problem. Any suggestions on what it could be?
1. Do you have a wideband installed on the vehicle?
If so, what are the air fuel ratios when this occurs?
2. Is the check engine light on?
If so what codes are being thrown?
lastresort576
Oct 28, 2009 11:30 AM
