PR4 versus P75 Intake Manifold
Old Oct 19, 2012 | 12:12 PM
j3wman's Avatar
Default PR4 versus P75 Intake Manifold
okay heres the deal and i honestly spent a half hour in the search tab trying to find this but info is scarce since nobody gives a **** over LS motors but, which flows better a PR4 or a P75 intake manifold?
my setup incase anyone is wondering
B18B
YS1 Transmission
B20 Cams
Wiseco 11.5 compression pistons
Eagle H beam rods,
Balanced and Micropolished crank
N1 crank pulley
Yokana Header (am getting PLM Header)
I have both manifolds in my garage and i can see visual differences, the PR4 looks like it has a large plenum so im wondering which one flows better?
pr4 left, p75 right
p75 left, pr4 right
Anyone ever flow tested these?
Old Oct 19, 2012 | 04:17 PM
Sr420Det's Avatar
Default Re: PR4 versus P75 Intake Manifold
shorter runners and bigger plenuem is better for top end power, vice versa for down low. sorry, thats all i got
Old Oct 19, 2012 | 06:15 PM
j3wman's Avatar
well the one with a big plenum has long runners
Old Oct 19, 2012 | 07:14 PM
Charlie Moua's Avatar
They both are very similar but the accurate truth is that the minor differences between manifolds aren't going to translate to any notable variance in power output.
At this point of your build, this the least of your worries.
IMHO I would just fork over some cash and get a used blox. I've seen them go for $80-140 used.
Get everything else and worry about the IM later pal.
If anything we can test both out on the dyno on a dyno-after-dark session this winter.
I do have a GSR IM that I could try to get it to fit on the LS head. I'd like to see how that does do.
Charlie Moua
Old Oct 20, 2012 | 12:04 PM
j3wman's Avatar
hey charlie if you wanna bring that to rockfalls tomorrow ill buy it off you since i can hack up one of the LS intakes and i got a friend whos a career welder
AGENT 99
Mar 4, 2025 12:41 PM
93grayeg
Oct 14, 2009 10:37 PM
acura_b18c1
71
Apr 30, 2007 09:21 PM
longislandek123
May 21, 2005 03:29 PM
