chipped p28
Old Oct 19, 2012 | 11:40 AM
ryanmh22's Avatar
Default chipped p28
i have a jet performance p28 ecu, what exactly is this jet chip doing for my car? what is it changing?
Old Oct 19, 2012 | 12:57 PM
grumblemarc's Avatar
The Grumpiest
Default Re: chipped p28
NO one can possibly know that but Jet and the previous owner that had it installed. If they are still in business, contact them directly.
Old Oct 19, 2012 | 01:03 PM
mayfly's Avatar
^^^what he said
now what is most likely done to the ecu is vtec engaging quicker and/or rpm range raised.
Old Oct 20, 2012 | 03:15 PM
Xpelspoon's Avatar
Would it be to late to have hondata do something to it and would be better then the jet chip? all jet dose is bump everthing up like timing and advance everything? at least hondata is tuneable....
Old Oct 20, 2012 | 03:23 PM
The Grumpiest
YOu can't reprogram a chip. Hondata is an add-on EMS that installs in the ECU. It's not cheap and will require additional tuning. Preferably by someone that knows how to tune. That will most likely incur an additional expense.
Since you never mentioned what mods are done to your engine there's a good chance Hondata would be overkill and not cost effective.
Contac Phearable and have them burn you a better chip to your specs. $35.
Old Oct 20, 2012 | 03:53 PM
Xpelspoon's Avatar
Thank you for the new info for me..
thirsk66
Feb 2, 2015 10:41 AM
JFG Kevin
Oct 26, 2004 04:11 AM
hYpE-R-29
Sep 12, 2003 05:21 PM
