GA Atl area - 98 Prelude 5 speed 98% stock
Old Oct 18, 2012 | 08:18 PM
dlndjh's Avatar
Default Atl area - 98 Prelude 5 speed 98% stock
1998 base model. 101K miles on the odometer. 98% stock. Only Invader style carbon fiber hood and new Pioneer front speakers are not stock. Original G-83P Eucalyptus Green Pearl paint. Previous owner broke the timing belt and a valve broke a piston. I bought the car in Sept. 2011 and replaced engine with 60K mile 97 model engine and head this past Summer. Runs perfect and strong - no oil leaks anywhere. All new gaskets. Original 5 speed shifts perfectly and is smooth as silk. No CEL, ABS or SRS faults. Nearly spotless interior and trunk. SH rims with red center caps and good tires. Everything on this car works down to the drivers window switch light (Yes, the A/C too!). NEEDS ABSOLUTELY NOTHING. A few bumps and bruises on the body but nothing unusual for a 98 model car. The common problems for 5 G Preludes have been fixed - no trunk leaks even in the heaviest downpour, inner door handles' chrome perfect, no sloppy wipers, EGR passages cleaned, front engine mount replaced (perfect insulator), no broken headlight mount tabs, no broken or cracked wires in the body to drivers door harness. Has always been a GA car.
In addition to the above I've done the following over the past year:
New parts:
Timing belt
Balancer shaft belt
Timing belt adjuster
Adjuster bearing
Water pump
Valve cover gasket kit
Oil pan gasket
Intake manifold gasket
Exhaust manifold gasket
Lower timing belt cover gaskets
Timing adjuster bolt grommets
Timing mark seal/plug
Ignition wires
Distributor cap, leak cover, and rotor
Denso Double Platinum PKJ20CR-L11 spark plugs
Denso 234-4092 downstream O2 sensor
Thermostat
Denso OEM alternator
Alternator / AC belt
Pwr steering belt
Air filter
Brake rotors all around
Front brake pads
Rear brake pads
Clutch release bearing
Clutch master cylinder
Wiper rod A
Wiper blades
OEM Prelude floor mat set
Brake and clutch pedal pads
Front seat anchor covers
Instrument panel and all indicator mini lights
Pioneer TS-G1647 door speakers
Antifreeze
Oil and filter
Honda manual trans oil
Brake fluid flushed, replaced and system bled
Clutch fluid flushed, replaced and system bled
Good used parts:
Carbon fiber hood
Both interior door handle assemblies
ABS pump (modulator)
Front engine mount
Clutch release fork
Previous owner had the following done and parts replaced from 2010 - 2011:
PCV valve
Clutch slave cylinder
Clutch disc and pressure plate
Flywheel resurfaced
Magnaflow catalytic converter
EGR valve and passages cleaned
$5689 / OBO
http://api.viglink.com/api/click?for...13506201932503
Name:  Picture 020 small.JPG
Name:  Picture 029 small.JPG
Name:  Picture 006 small.JPG
Name:  Picture 012 small.JPG
Old Oct 19, 2012 | 11:46 AM
dlndjh's Avatar
Default Re: Atl area - 98 Prelude 5 speed 98% stock
Rise up!
Old Oct 20, 2012 | 12:34 PM
dlndjh's Avatar
TTT
Old Oct 22, 2012 | 09:29 AM
dlndjh's Avatar
Bump..
Old Oct 23, 2012 | 05:46 PM
dlndjh's Avatar
Bump everyday there's so many cars for sale on here...
Old Oct 25, 2012 | 10:00 AM
dlndjh's Avatar
TTT
Old Oct 25, 2012 | 12:36 PM
JDMslutITR's Avatar
trade for near perfect honda 954RR of equal worth
Old Oct 25, 2012 | 01:04 PM
dlndjh's Avatar
I only do four wheels...Thx for the offer tho'
Old Oct 26, 2012 | 02:20 PM
cybergreencivic's Avatar
Love that color lude. Looks to be in great shape.
Old Oct 27, 2012 | 05:30 AM
dlndjh's Avatar
Thanks....and it is.
Old Oct 28, 2012 | 09:40 AM
dlndjh's Avatar
SOLD....
97soup
Aug 21, 2007 08:30 AM
RXHEAVN
Dec 2, 2006 10:10 AM
nouse4aname
Aug 15, 2004 02:22 AM
nver2
Feb 9, 2004 11:35 PM
