Integra not starting need ideas on what to do.
Old Oct 18, 2012 | 04:43 PM
TEG_UR_IT's Avatar
Default Integra not starting need ideas on what to do.
Year: 2001
Model: Integra GS Automatic
Miles: 140K Plus
Problem: Crank but no start
Description:
Okay so recently I had installed a viper one way remote start system into the car. It also controls the power locks from the key fob. Obviously the car has an immobilizer built into the ecu. I removed the immobilizer out of the ecu. Tested out the remote start and it fired right up. Everything was gravy. THEN I noticed something weird right as I was leaving my friends garage after finishing up the install. I went to manually start it up with the KEY and it cranked for a very long time before the car started.
So the car has been started up every morning with the key fob before work, and it starts right up no problem. After work come back to the car and try to start manually with the key, the same symptom: takes a long time to start (like 7-10 seconds).
1.) SO I try to trouble shoot it. I start the car with the key fob, start right up. Put key in, turn to the on position and press the brake pedal to give me control. Then I turn off the car by taking out the key. Try starting it with the key after a few seconds AND it takes forever to start up.
2.) So after I was able to start it up after 7-10 seconds, I turn it off by taking out the key. This time I try starting it back up manually again. Guess what, STARTS right up no problem. (Doesn't make much sense).
So this goes on for about 2 - 3 weeks. This Morning it decides to not want to start from the keyfob. I hear the car wanting to start from the inside of my house. I see it crank for 5-7 seconds. Then it repeats that 3 times before it automatically quits. I can't start it manually either. Just cranks. I know that it has fuel cuz I can smell it after trying to start for awhile. I haven't tried testing for spark yet because its raining and it cold.
**Before all of this the car never had a starting problem.
Please give me a guide of where to start and what to check next.
I am thinking of checking out the distributor this weekend and see if that is the cause.
Thanks a whole bunch, please comment if I should provide more info on the problem.
Old Oct 19, 2012 | 06:47 PM
mike703's Avatar
Default Re: Integra not starting need ideas on what to do.
you need to check for spark simple as that. also check your air filter and report back.
Old Oct 19, 2012 | 10:53 PM
kchungb17a's Avatar
I would talk to your installer to see what he has disabled with the alarm. I don't think it's a coincidence that this started after the install. Check your immobilizer disable too.
Old Oct 20, 2012 | 11:11 AM
fcm's Avatar
fcm
Old Fart
Ditto both the above^^^.
The first thing I would want to know is why was the stock immobilizer "removed"???
You can not just remove the immobilizer "chip", it must be replaced with a by-pass "chip".
If this was done, replaced with bypass "chip", my guess is the bypass is the problem. 94
In the case of adding a remote start to a car with an immobilizer, all that is needed is a bypass module and there are more then a few to chose from.
bigJOE671
Audio / Security / Video
Sep 1, 2012 06:18 AM
thunderboy
Honda Civic (2006 - 2015)
May 14, 2011 06:04 PM
OldskoojdmDA9
Mar 12, 2010 12:13 PM
mynameizstitch
May 5, 2008 09:09 PM
deadstar
Oct 27, 2004 12:16 PM
