Headers B18C type-r 96
Old Oct 17, 2012 | 09:40 PM
Luisef's Avatar
Default Headers B18C type-r 96
hi friends i want to buy headers of my engine jdm B18C, according to their experiences hear suggestions which give the best performance?
Old Oct 18, 2012 | 11:20 AM
bryantran84's Avatar
Default Re: Headers B18C type-r 96
Get a real Toda header more performance and more power ..
Old Oct 18, 2012 | 12:22 PM
NODAKDCteg's Avatar
real HyTech header if you got the money
Old Oct 26, 2012 | 12:59 PM
Slain's Avatar
how much do you want to spend and do you have something to tune the car with ?
Old Oct 27, 2012 | 06:15 AM
soulassassin13's Avatar
From everything that has been posted/discussed over the past few years for the best back for your buck: (1)SMSP (2)Hytech anti-reversion (3)Toda.
Old Oct 27, 2012 | 06:20 AM
halocsboyz's Avatar
Ttttttttttttttttttt
Old Oct 28, 2012 | 06:13 PM
Luisef's Avatar
I want to know which options must not exceed $ 800 and that provide proven performance, I watched Hytech, RMF, MegaPower, but not sure which of these is the best, and now is starting to give better performance by b18
Old Oct 28, 2012 | 08:54 PM
Todd00's Avatar
I said I don't want a title!
Try a search. There hasn't been any "new" findings since about 2005 with the B-series motor. What worked best back then still works now.
Old Oct 28, 2012 | 10:01 PM
howl's Avatar
Search the all motor section, lots of info as well as dyno charts there. But as Todd00 said, not much has really changed for the b-series. Just a whole lot of replicas flooding the market
IMO since you're on a budget i'd look at jdm itr header. Gets decent power and you can't beat the OEM look. Only issue with that header is ground clearance so watch out. After that DC 4-1, Skunk2.
Old Dec 2, 2012 | 02:25 PM
shinobi550's Avatar
A header won't do jack for you if you not using bigger cams. I rebuilt my ITR in stock form with head work with my 98spec ITR header and made 190whp with Stock ITR cams....I'm happy with the power, just remember better header needs bigger cams. When you search you will see alot of dyno sheet with name brand header on stock ITR hitting 186-192 hp. That's proof that you will **** away 1300 buck on header if that's all you get. Parts compliment each other you can't upgrade one thing without something else suffering in the motor. I use my ITR cams to conceal power for regulations .
martin88
59
Feb 1, 2016 05:27 PM
b18c inside
Sep 14, 2005 01:39 PM
bukbukintegra
May 26, 2005 07:12 AM
igottab18
Feb 5, 2003 04:47 PM
civicmatt
Nov 14, 2002 04:53 PM
