db7 with jdm b20z automatic swap need help...
Old Oct 17, 2012 | 08:43 PM
nycpatron's Avatar
Default db7 with jdm b20z automatic swap need help...
Hi I just got an 94 4 door teg automatic with a jdm b20z swap with the 2wd crv tranny already on the integra but the wiring is not done yet I bought it like that.
I have a ecu for the motor I never done a auto swap but done many swaps before and wiring also so I think I can handle it.
My questions are:
Does the 00 crv use a separate ecu (tcm) for the tranny? I searched and can only notice it on the 4wd not the 2wd.
I dont mind using the jdm ecu we have no kind of inspections out here so theres no problem with that but I would like it to run like oem also I dont wanna switch to manual I want to keep it auto and would like to use the crv tranny that it already have on there.
If I use the b20 ecu and basically convert my car to obd2b is there anything else I need to worry about??
I have an extra auto p75 ecu and a ls tcm if I have to use the p75 and chip it can I use the tcm from the ls onto the b20z crv tranny?Or use the ls tcm with the jdm b20 ecu?
Thanks in advance
Old Oct 19, 2012 | 04:50 AM
nycpatron's Avatar
Default Re: db7 with jdm b20z automatic swap need help...
Nobody?
Old Oct 22, 2012 | 03:18 AM
nycpatron's Avatar
No one at all???
Old Oct 22, 2012 | 03:48 AM
el crapitan's Avatar
seperate tcm, yes. and if it were me, i'd just stay obd1. use the p75 ecm, obd1 distributor.
also, the b20z was never available in the japanese market. it's not a jdm motor
Old Oct 22, 2012 | 07:29 PM
jason saizan's Avatar
I'd use tge ls ecu obd1 much simpler . I'd drop tge auto tranny tho an put a 5 speed an have a bad *** B20 swap lol
Old Oct 23, 2012 | 08:45 PM
nycpatron's Avatar
Na I just wrote b20z as reference but it says b20b but its the exact same thing as a b20z because its the 00 jdm b20b ...
I wish i could just use the ls auto tranny but it didnt come with it and who ever did it did a full swap so its already on the car with custom brackets for the crv tranny...
You sure the b20z has a tcm? Because on obd1 the ecu has 3 plugs and the 4th witch controls the tranny goes to the tcm but on the ecu I have all 4 plugs are on the ecu just like an ek and so far it looks like I wont have no problems but im not sure yet im still working on the car ill post my results so it helps other people that decide to do this because I really cant find anything on the internet about it.
The reason im avoiding changing the tranny also is because of the cost of things out here where im at an also it would be so much easier to find a jdm type r motor than to get everything to switch my car to manual.
Old Oct 23, 2012 | 08:47 PM
nycpatron's Avatar
I wish but im really not doing this to go fast just trying to use what I got plus my wife really likes the car and wants to learn but if the crv tranny has to go ill do the manual swap.
Old Oct 25, 2012 | 07:43 PM
nycpatron's Avatar
Almost done with the wiring but if anyone else has any more input please let me know thanks
Old Oct 29, 2012 | 07:59 PM
nycpatron's Avatar
Got the engine running if anyone is interested!!!
Old Oct 29, 2012 | 09:28 PM
right on. that the p8r head you have on there?
Old Oct 30, 2012 | 05:06 PM
nycpatron's Avatar
This is how it looks like
I know its dirty I just got the car so im working on everything I was just woried about getting the car started and cleaning the interior.
Old Oct 30, 2012 | 07:30 PM
look near the date stamp of the head. it'll say either p8r or p75
Old Oct 30, 2012 | 07:49 PM
jrunager's Avatar
What intake did you use? In my ek Civic I have to use an LS intake and LS transmission because as far as I know neither fit an ek. I'm a bit curious how I'm going to be able to use a P75 auto ecu without a TCM to run the transmission but as far as I know all I need is the modified obd2 to obd1 conversion harness from rywire.
Old Oct 31, 2012 | 02:20 PM
nycpatron's Avatar
It says p75-6 and the date is says 00 ...its a low mile motor imported from japan stock came with everything even the crv fuce box with the jdm ecu p7j RHD engine harness everything attached I got the car with everything when I bought it but the other owner just bought the engine a week before he sold it to me I was supposed to do the wiring for him but ended up doing it for my self I actually traded my 91 Ef with a d15b 3stage vtec for it so I think it was a really good deal specially here in dominican republic cars are way overpriced but most of auto parts are brought from japan...
Old Oct 31, 2012 | 02:26 PM
nycpatron's Avatar
I just used the stock intake that it had but I know the older crv motors have that big intake you cant use newer crv come with this lower intake that kind off looks like ls but with something attached to it on top.
If you convert to obd1 you have to use the TCM obd2 doesnt its all in the same ecu as far as I know so your going to have to wire in the ls tranny to the tcm correct me if im wrong.
Old Oct 31, 2012 | 06:39 PM
jrunager's Avatar
Are you saying I shouldn't convert to obd1? Or are you saying I'm going to have to convert to obd1 and keep my obd2 to run the transmission like a tcm does?
Old Oct 31, 2012 | 07:59 PM
nycpatron's Avatar
Well all im saying is if you convert to obd1 you are going to have to wire your TCM to the tranny ...with my motor and the ecu it came with (obd2b) the wiring for the tranny was already there because the ecu controls it not like the obd1 ecu where you have a TCM...I only had to do wiring for lights on the cluster like coolant temp and oil light and main relay wiring nothing at all with the tranny since it was all there on ecu...
If your not planning on doing mayor upgrades since your auto why even convert to obd1 ? If I ever do a manual swap its because I want to go faster and then I would convert to obd1 but if you not going to tune your ecu why even bother converting to obd1? because thats the only reason people want obd1 is because you can tune the ecu.
If your car is obd2 and you have your obd2 ecu and everything is already wired I suggest keep it that way unless for some reason your building a auto race car.
But if you ever decide to change your tranny and do some upgrades then yeah convert to obd1...
You can also run both ecu I guess if you really want to but I would only do that if I really had to.
But thats just my opinion.
russel_h22a
Honda CR-V & Element
Sep 6, 2014 10:15 PM
Mr.Civic
Sep 11, 2012 03:31 AM
brad22486
Jan 25, 2012 09:46 AM
vtec tegboy
Sep 7, 2007 01:38 AM
ek44
Oct 11, 2002 10:10 AM
