Leak Hunting, Is This Bad?
Old Oct 17, 2012 | 01:14 PM
hatchnewb's Avatar
Default Leak Hunting, Is This Bad?
So I got fed up with the water pooling up in my car everytime it rains. I started by taking off the cowl, found a lot of debris in there. After shop vac'ing it all out and degreasing I found the culprit hole into the footwell. there is more rust than I thought under there.
How bad is this?
Pass side.
Hole into footwell. Drivers side.
under the drivers side fender.
Old Oct 17, 2012 | 01:54 PM
Eddie's Avatar
Master Ninja
Default Re: Leak Hunting, Is This Bad?
I'd say get it fixed that look's pretty bad.
Old Oct 17, 2012 | 02:28 PM
hatchnewb's Avatar
The real question is, is it worth it?
Old Oct 17, 2012 | 02:34 PM
pye174's Avatar
nobody can tell a car enthusiast if its "worth it".
Old Oct 17, 2012 | 03:00 PM
hatchnewb's Avatar
I mean what would be the cost of fixing something like this.
Old Oct 17, 2012 | 04:03 PM
Masster Shake's Avatar
LOL
Old Oct 17, 2012 | 04:27 PM
hatchnewb's Avatar
Both unhelpful posts
Old Oct 17, 2012 | 04:30 PM
Fliptard's Avatar
well, you could piece some flat steel together, cut out the rust and weld it back together, might not look pretty if you can't fab good, but at least it'll fix it...
Old Oct 17, 2012 | 05:23 PM
hatchnewb's Avatar
Yes, you make it sound so easy.
Old Oct 17, 2012 | 05:28 PM
hatchnewb's Avatar
17, 31, and 29?
Old Oct 17, 2012 | 06:26 PM
hatchnewb's Avatar
not 17 i meant 16
Old Oct 17, 2012 | 06:27 PM
Fliptard's Avatar
prolly will need 17 as well.
Old Oct 18, 2012 | 12:15 PM
hatchnewb's Avatar
17 is good, no rust.
Old Oct 18, 2012 | 07:52 PM
pye174's Avatar
it will cost $1000+ if I were you i would buy a can of expanding foam and see if that prevents water from coming into your car.
Old Oct 22, 2012 | 01:43 PM
hatchnewb's Avatar
What would ya'll suggest to spray on the existing rust to prevent it from spreading? What about some rust converter and some rhino liner?
RDAYA0
May 27, 2008 07:20 AM
dejavu_88
Mar 14, 2008 05:30 PM
CRX MASE
10
Jul 13, 2006 11:20 AM
HaiSpeedRacer
Oct 5, 2005 11:30 PM
hgc
Feb 11, 2005 08:30 AM
