japanese cars a/c and heater.
Old Oct 17, 2012 | 09:05 AM
Protosouls's Avatar
Default japanese cars a/c and heater.
This has bothered me for some time now but I will ask now. Why is it that in Japanese car you need to have the a/c on in order to heat your car so that the windows do not fog up. I also own a American car and I do not need a/c on to use the heater... any help will be awesome! Im just curious. Thanks!!!
Old Oct 17, 2012 | 09:23 AM
doctorbee's Avatar
Default Re: japanese cars a/c and heater.
thats weird, all HVAC systems, foreign and domestic, work using the same principles
Old Oct 17, 2012 | 10:40 AM
Protosouls's Avatar
Have you had an encounters with this? Also which is weird needing a/c on or not needing it on?
TheMuffinMan's Avatar
He knows where you live!
A lot of them do it without you knowing.....
The whole point of having the A/C on to defrost is it dehumidifies the air.
Old Oct 18, 2012 | 09:30 AM
Hidenplanvew's Avatar
Muffin is on point, this wasent a requirement or wasent commin practice till around like 99 or 00+- . It should be only for defrost you should be able to turn on your heater in other modes and should be just heat.
Old Oct 18, 2012 | 12:00 PM
doctorbee's Avatar
yeah ac is good at removing moisture from air, hence the need for a drain tube from the evaporator. whenever i defog windows i use heat and ac at the same time. newer cars may do it automatically
Old Oct 18, 2012 | 11:59 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Muffin man is correct, however a little known fact is that on some model cars (Honda in particular) you can disable the AC/defroster combo. The info can usually be found in a legendary book called....wait for it.........the owners manual. Of course no one ever reads that.
Old Oct 21, 2012 | 04:17 AM
Lost Again's Avatar
and GM cars were doing this in the 70's
Old Oct 21, 2012 | 10:38 AM
nus_dogg's Avatar
x2!
mannydhanju
Jan 14, 2009 12:19 PM
gpdxtrm
Feb 16, 2008 07:47 PM
Shizznaz
Jan 31, 2005 09:02 PM
Seedc2
Mar 22, 2002 02:41 PM
Trickturn
Feb 12, 2002 10:19 PM
