1994 Honda Civic EX Sinking Pedal
Old Oct 16, 2012 | 10:16 PM
Tudm91's Avatar
Default 1994 Honda Civic EX Sinking Pedal
Alright so title says it all I have a 94 honda civic with a sinking pedal.
Recently bought a rebuilt Master cylinder(tonight actually), bench bled it, bled my whole system till the fluid was as clear as it could be. Tried it out after and the pedal still sinks half-way before applying pressure to the brakes.
Things to note:
-My rotors are wearing the brake pads unevenly(will be replacing rotors within the next few days anyways)
-My suspension is crap; need new shocks and springs(possibly new cv joints and all that)
-I'm not sure of the condition of my drums. Haven't pulled them apart yet(probably going to replace these too with the rotors)
Could a bad bearing cause this? Maybe a seized adjusting star wheel in my drums? The unevenly wearing rotors might cause this issue?
Any opinions would be appreciated. Thanks!
Old Oct 16, 2012 | 10:23 PM
nealnanoHX's Avatar
Default Re: 1994 Honda Civic EX Sinking Pedal
Check the rear wheel cylinders. If they are leaking the pedal will get spongy again. If they are good try adjust the rear brake shoes.
Old Oct 16, 2012 | 10:39 PM
Tudm91's Avatar
Will do, I'm hoping it's just that they need to be adjusted...
Old Oct 22, 2012 | 09:53 AM
Tudm91's Avatar
Found that after replacing my MC the brake fluid has been contaminated again.
Ahhh jeez time to check my brake lines...
Old Oct 22, 2012 | 11:08 AM
jawnewbe2's Avatar
could be your calipers check your front ones and then check your drums
InTheZoneAC
Suspension & Brakes
May 21, 2014 06:31 PM
ess-eye#7
Sep 3, 2010 02:52 PM
JDMflavor_EJ
12
Dec 5, 2007 07:51 PM
tvrsir
Jun 20, 2004 06:24 AM
