Cheapest place to buy endlinks and brackets to make an Integra swayba fit my ek?
Old Oct 16, 2012 | 02:32 PM
jrunager's Avatar
Default Cheapest place to buy endlinks and brackets to make an Integra swayba fit my ek?
Sorry I've searched this but I'm still confused where to buy the cheapest endlinks and brackets to fit my Integra RS sway bar.
Old Oct 16, 2012 | 02:49 PM
howangseg's Avatar
Default Re: Cheapest place to buy endlinks and brackets to make an Integra swayba fit my ek?
ebay. 25 for endlinks 12 for d brackets and bushing (energy suspension)
Old Oct 16, 2012 | 02:53 PM
dirty19's Avatar
Ridin Dirty in Cali
Well pswd JDM comes to mind.
Dare I say blox?
Energy suspension for the d's like howangseg says. but id get the ones that have the lube nipples.
keeps the bar from binding
Old Oct 16, 2012 | 03:04 PM
jrunager's Avatar
How about these? Are they good or junk though?
http://www.partsgeek.com/catalog/200..._bar_link.html
Old Oct 16, 2012 | 03:13 PM
dirty19's Avatar
Ridin Dirty in Cali
You want a front sway or rear?
We thought you wanted rear....
Old Oct 16, 2012 | 03:36 PM
jrunager's Avatar
rear sway bar...you just have to scroll down the link
Old Oct 16, 2012 | 04:04 PM
98civdx's Avatar
Master Detailer
Dare I say blox?
You better not.
Blox endlinks are junk. I found out the hard way...
ES bushings are fine, if you can get the ones with nipples so you can keep them lubed.
as far as endlinks, I reccomend going OEM. Check Hondapartsunlimited.com for better pricing on them.
Old Oct 16, 2012 | 04:33 PM
jrunager's Avatar
Originally Posted by 98civdx
You better not.
Ouch! Kind of pricier than I had expected.
http://www.hondapartsunlimited.com/o.../52321-s04-003
http://www.hondapartsunlimited.com/o.../52320-s04-003
Old Oct 16, 2012 | 04:43 PM
HondaPartsHero's Avatar
Technical Hero
Don't cheap out or they'll blow out quick. I bought some off eBay from I believe world suspension and they blew out quick.
Old Oct 16, 2012 | 05:00 PM
jrunager's Avatar
Yeah it looks like I'm going to have to wait on putting my sway bar. The wife isn't going to like me spending that much money on car parts right now.
I never expected the sway bar to cost a lot less than the links.
Old Oct 16, 2012 | 05:10 PM
98civdx's Avatar
Master Detailer
Yeah, they aren't cheap, but the thing is they will last.
I had blox endlinks and they bearly made it a year ($40 a set) they were the adjustable ones.
Here is another option. ~$50 for the set.
http://www.jhpusa.com/store/pc/viewP...idcategory=640
Hardrace is pretty good.
Old Oct 16, 2012 | 07:41 PM
jrunager's Avatar
Yeah I was wondering about those so I may go that route when the time comes. I'm now wondering where to get the brackets now. Don't I need bushing also?
Is this what I need but I need two of them right?
http://www.hondapartsunlimited.com/o.../52317-s04-000
Last edited by jrunager; Oct 16, 2012 at 07:43 PM. Reason: Maybe found what I was looking for
Old Oct 16, 2012 | 07:53 PM
98civdx's Avatar
Master Detailer
If you don't have #30, you will need it, yes you will need 2.
That bolts to the subframe the D bracket(sway bar bushing) bolts to it.
You will need to 4 10mm bolts, 4 lock to bolt the #30 onto the subframe though. (this will require slightly drilling out the bracket.)
The D bracket is #28, and the bushing, #29. If you were to go OEM. However the ES part will do.
Old Oct 16, 2012 | 08:43 PM
dirty19's Avatar
Ridin Dirty in Cali
parts 28,29
you can get es ones probably a little more stout than stock.
Hard Race are pretty good too IMO and experience
Old Oct 17, 2012 | 03:33 PM
jrunager's Avatar
So I need parts:
Qty 2 - #28 HOLDER, RR. STABILIZER (Do I need this if I buy #29 from hardrace?)
Qty 2 - #29 BUSH, RR. STABILIZER (13MM) (I'll probably goe hardrace)
Qty 2 - #30 BRACKET, RR. STABILIZER (I'm a little confused on what would need to be drilled here)
Qty 1 - #31 LINK ASSY., R. RR. STABILIZER
Qty 1 - #32 LINK ASSY., L. RR. STABILIZER
Qty ? - #35 004 BOLT-WASHER (8X20) 0.30 0.21 Qty:
Qty ? - #36 004 BOLT, FLANGE (8X18) 0.85 0.60 Qty:
These instructions don't mention drilling the brackets so I'm a bit confused about that part. I'm guessing it might be more apparent once I start the install.
http://socalcivic.com/forum/showthread.php?t=17313
Old Oct 20, 2012 | 06:39 PM
jrunager's Avatar
Since the sway bar is 14mm (DC2) would this bushing set work?
Amazon Amazon
jdmsir4dr
Suspension & Brakes
Apr 27, 2015 07:56 AM
Teh Boss
Dec 30, 2012 07:48 PM
ZoobeaR
Suspension & Brakes
Sep 2, 2005 08:14 PM
