89 crx hf -- Is it OBD1?
I have a crx hf i just bought.needs a bit of work but its got a sohc zc engine 1.6.the person said it was obd1 conversion but idk how i can tell if thats true?i want to just buy an si harness and take out watever it is they modified cus it looks like crap and wires everywhere.there is no check engine light on and everything seems to work fine.i guess its running with a p06 ecu also.wat should i do.
P06 ECU = OBD1
This may not be ideal but if there's nothing wrong with the way it runs and it's literally just wires everywhere (no splices/butt connectors/etc) you can just buy some wire loom and clean it up.
lol
I would say at least clean the wires up with some black loom and electrical tape, make sure there aren't any loose connections. Its true to say "if its not broke, don't fix it" but....you can always make it better the right way
