windsheild wipers dont turn off
Old Oct 16, 2012 | 07:30 AM
Davidkak's Avatar
Icon6 windsheild wipers dont turn off
I just recently bought a 94 integra rs. This morning omw to work i turn the switch to take some of the fog on and now the windshield wipers wont stop. I tried disconnecting the battery and fuse and letting it sit.for an hour and nothing!
The switch is off and it still goes on.
anyone have a clue?
Also wondering if its the turn signal/windshield wiper switch..and will an eg switch work?
Old Oct 16, 2012 | 07:45 AM
JuicedUpRice's Avatar
Default Re: windsheild wipers dont turn off
It could be the switch..
or
sounds like your wiper motor is bad
or check windshield wiper relay(if there is one,i dont even know)
Old Oct 16, 2012 | 03:02 PM
1998GsRIntegra's Avatar
If the car is off and the battery is disconnected I'm not sure how its even possible for the windshield wipers to function.
Old Oct 16, 2012 | 03:05 PM
vitamin_c95's Avatar
i hope he means disconnected battery to shut it off, then when he reconnected they stay on... Verify OP?
Old Oct 16, 2012 | 05:43 PM
Davidkak's Avatar
So i disconnected the battery and fuse to see if maybe it would get restarted or something. But.when i plugged them both back in, the windshield wiper kept going off.
Its stuff in the low settings. And if i try to turn it to a different setting it doesnt go to it...
"Vitamin C95" -correct.
Any idea?
Old Oct 16, 2012 | 08:12 PM
mark@silbernage's Avatar
The motor (has contacts), the Integrated Control Module (ICM) (is involved), and the combination wiper switch are all candidates. The motor has a 'park' signal it sends to the ICM to keep it from stopping in the middle of your window.. perhaps if that switch in the motor is not making contact (or wiring is open) the ICM is just waiting for the wiper to return 'down' - which it never sees. Hopefully, it's not an ICM problem.
You'll want the electrical diagram and a volt/ohm meter to trace the signals and see where it's failing.
Sorry I don't have a feeling for which is more likely.
Old Oct 17, 2012 | 12:36 PM
Davidkak's Avatar
I.will change.the switch first and see if that helps. Ill keep u guys posted.
Thanks for the advice everyone!
Old Oct 17, 2012 | 01:43 PM
btw...mine does this intermittantly. I think its my motor tho. I had an extra switch and swapped it but it didnt fix.
Old Oct 17, 2012 | 05:34 PM
fcm's Avatar
fcm
Old Fart
mark@silbernage is on the correct path, my guess is it is a defective park function, only thing that would keep the wipers on once the switch is off, or possibly the switch itself.
Unplug the wiper switch, if the wipers keep going it is a defective park function, most likely stuck contacts in the wiper motor assembly.94
OgKush
Jan 21, 2010 04:10 PM
turboteg90
Nov 15, 2009 05:26 PM
kaotikvizion
21
Apr 17, 2009 09:32 PM
floored4door
Apr 26, 2007 03:08 PM
trutuner
Aug 22, 2002 07:56 PM
