Gsr having problems with hid lights throwing check engine lights
Old Oct 15, 2012 | 10:52 PM
batto24GSR's Avatar
Default Gsr having problems with hid lights throwing check engine lights
so i go to get in my car and the first thing i noticed was it smelled kinda weird/different idk if im over thinking it then i started my car up and it throwing abs light srs light maintance required light and one other light i believe and then when i turned my lights on my hid lights both flickered then turned off and wouldnt come on but my side marker lights stayed on and also my brights came on so then i unplugged my battery and amps and started it back up and my srs light came on so did the maintance required light but the abs did not come on. then when i turned my lights on the same thing happened they turned on the went off and also another strange is that when i turn my car off i will leave the lights on for a sec and as soon as the motor turns off the hid lights come back on then flicker off. anyone having similar problems or anyone know anything about
Old Oct 16, 2012 | 10:38 AM
hufflepuff's Avatar
Default Re: Gsr having problems with hid lights throwing check engine lights
The run-on sentence makes your thoughts difficult to follow. Did you make any other changes during the HID install? Did you disconnect the battery while you were donig all of your wiring work?
Stunna MIKE
Jun 26, 2011 03:19 AM
CPreston
Lighting
May 21, 2009 11:35 AM
bknewtype
Sep 30, 2008 12:45 PM
AndyD
Sep 20, 2003 02:09 PM
