integra b20v sputtering, dying at idle
Old Oct 15, 2012 | 05:37 PM
Superqwak's Avatar
Default integra b20v sputtering, dying at idle
Recently built a b20v type r style pistons skunk2 valve train. I drove the car for around 200 miles and only died on me once had no other problems. Got it tuned and had to get temp 9 ngk 5238 spark plugs and torco accelerator because my engine was pinging. Car got tuned ran great. About a week later I blow vacuum seals on intake manifold car dies will not start. Plug it back up and starts up eventually. Now the car sputters at 4 or 5000 rpm but than picks back up. Car than dies when I come to a stop sometimes not right away idles fine than just turns off. And I replaced cap and rotor with orieley parts recently, cleaned iacv. Haven't changed fuel filter in about a year. No error codes tuned on s300. Please help. Would it be injecters? I bought used 440 rc. Fuel filter? Have walboro 255. Fuel pressure at around 50psi.
Old Oct 15, 2012 | 05:43 PM
EsotericImage's Avatar
Retired Moderator
Default Re: integra b20v sputtering, dying at idle
so is it tuned on these 440's and on 50 psi?
I would roll back to your tuner and have him datalog it
Old Oct 15, 2012 | 06:08 PM
Superqwak's Avatar
Yes tuned on 440 and the 50 psi
Old Oct 15, 2012 | 06:26 PM
bks84's Avatar
Loved
what cams?
having to run ngk 9's and octane booster on an rs machine "itr" piston sounds like you have **** tune.
i had a similar build using the "itr" pistons, gsr head, skunk2 pro 2's and i had ZERO pinging...
Old Oct 15, 2012 | 09:34 PM
Superqwak's Avatar
Originally Posted by Cpt. xThread
what cams?
Using s2 pro 1 compression is around 12
Old Oct 16, 2012 | 10:30 AM
Retired Moderator
Bad gas maybe? Like I said, time to see your tuner so he can see whats going on.
We/You can sit here and take stabs in the dark, but hooking up a laptop will be the most accurate and quickest to pin point the issues.
Old Oct 16, 2012 | 12:28 PM
Superqwak's Avatar
Ya going to change fuel filter, cap and rotor, check spark plug gap, because they never tapped them I believe. And if that doesn't work burn off this gas I got and see how that goes. Will give my tuner a call before hand. I have dataloged this, any suggestion ob what to look for. I am pretty new to using my s300
Old Oct 16, 2012 | 12:34 PM
Superqwak's Avatar
Old Oct 16, 2012 | 12:45 PM
Superqwak's Avatar
Old Oct 16, 2012 | 01:25 PM
Superqwak's Avatar
eg6noise
Mar 9, 2019 11:19 AM
GaryTuesday
Jan 4, 2014 10:32 AM
jdragon1974
Jun 28, 2013 08:04 AM
snmont01
Honda Civic (2001 - 2005)
Jul 7, 2011 04:31 AM
delslow302
Mar 22, 2009 03:49 PM
