Hood clearance
Old Oct 15, 2012 | 08:59 AM
drummerdude's Avatar
Default Hood clearance
I am planning a swap through the winter, and I can't decide which shell I should use? The swap I will be doing is one of the swaps that needs extra hood clearance. I have a 97 integra shell, but there is also another one for sale in my area a 98 with a jdm front end...
which one has more hood clearance... usdm integra or jdm 98+ integra?
Old Oct 15, 2012 | 09:43 AM
j13's Avatar
j13
Default Re: Hood clearance
Same clearance. Hood risers will be needed depending on swap. Jswaps won't work without a hole in the hood.
Old Oct 15, 2012 | 10:08 AM
lawjdl16's Avatar
Which swap are you doing? I think the J swap is the only one with clearance issues, and like the guy before me said, that cant be done without a hole in the hood, I know my H22a swap didnt have clearance issues and neither does my buddies K24..both in USDM Integras
Old Oct 15, 2012 | 10:50 AM
j13's Avatar
j13
I can't think right now, but it was one swap that required the hood webbing to be cut out, not sure what car/swap. If it's an integra, h/b/k/f swaps will be without risers.
Old Oct 15, 2012 | 11:41 AM
J32 swap... I was told if I use the hasport dual mounts and use the lower holes with an accord intake manifold... it'd clear with the webbing cut out, but I don;t like the idea of less ground clearance... so I'll probably end up doing some sort of a custom cowl hood. I was hoping the jdm front end had more clearance, but I guess thats out the window.
manicmechanic
Jun 28, 2009 09:10 AM
boosted28
Dec 17, 2007 06:54 PM
willymccoy
Apr 1, 2007 12:53 PM
ekmotorfiend
Aug 26, 2005 05:51 PM
Luserkid
May 8, 2003 07:59 PM
