00 GS-R with Chipped OBD1 ECU No Power.
I googled but it is difficult to find an something with the same kind of set ups and symptoms.
The car has new piston rings, all new gaskets, new valve stem seals, new dizzy, new spark plugs, and a few new tranny parts.
I don't know what kind of chip/tune it has. It starts up and idles great. If the car is cold, it drives almost as well as it should. If the car is warmed up, no low end power. I have to rev it off the clutch at above 2500 RPM. It doesn't bog down so much as it just doesn't accelerate. Once I'm above 2500 rpm in any gear there is enough power (although it's still lacking). Is this a fuel issue? Should I try a new ECU?
speedooo
Northeast (Sales)
63
Nov 14, 2009 07:08 AM
