96 B18B1 Ignition timing
Old Oct 14, 2012 | 07:27 PM
joshd_bh's Avatar
Default 96 B18B1 Ignition timing
I bought a 96 Integra Ls motor off of CL and It runs fine. Swapped it into an EF, but that doesn't matter. I am looking to increase performance and the distributor is already advanced as much as possible like so: What would putting it back to the neutral or retarded possition do?
Old Oct 14, 2012 | 09:08 PM
el crapitan's Avatar
Default Re: 96 B18B1 Ignition timing
if your distributor is advanced all the way, somethings wrong. check your valve timing to see that it's not off a tooth
Old Oct 16, 2012 | 10:41 AM
hufflepuff's Avatar
reducing ignition timing beyond factory settings can make for a rough idle, reduced power, and increased fuel consumption.
Aren't you getting ping with full advance? You running premium?
deving916
15
Mar 28, 2012 05:38 AM
alperx
Engine Management and Tuning
Jun 7, 2011 05:00 AM
brusk13
Jan 11, 2006 07:01 PM
