Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Replacing O Ring on pipe coming out of water pump
Old Oct 13, 2012 | 11:05 PM
Ainsworth03's Avatar
Default Replacing O Ring on pipe coming out of water pump
I just recently found a small leak coming out of the pipe that leads out of the water pump to the thermostat. I did research and it sounds like I blew the O ring that goes there. Here is my question. How do I take the pipe off to replace the O ring? Here is my car info and short situation on what happened:
2008 Honda Civic 1.8L
Car temp started rising and pulled over to notice the company that changed my oil and checked my fluids didn't check my coolant. It was empty. So car overheated. Put water in it and slowly leaked from time to time. Removed belt and alternator to notice coolant leak from the connecting pipe from water pump to thermostat. Curious on how to get the connecting pipe off and replace the O ring. Anything helps! Thank you!
Old Oct 19, 2012 | 06:34 PM
mike703's Avatar
Default Re: Replacing O Ring on pipe coming out of water pump
http://civic.hondafitjazz.com/A00/HT...000DAAT00.html
Old Jun 27, 2014 | 12:56 AM
gpro's Avatar
Bump. I'm having the same issue. Part #19505-RNA-A00 from link below as shown as Ref #14.
http://estore.honda.com/honda/parts/...n=&b=E++15&dl=
How do you remove this pipe?
JuneBugDrfter
Feb 5, 2013 08:57 PM
krysted9354
Jan 27, 2009 03:34 PM
k24ef
Jun 22, 2007 03:19 PM
swt_666
Apr 8, 2007 02:23 PM
