which camber kit do I get??
Old Oct 17, 2002 | 04:21 PM
ZERO COOL's Avatar
New User
Default which camber kit do I get??
I really need to get the camber adjusted on my front wheels but I'm not sure what to get. When I replaced my hf motor with a b16 I had to replace the brake assembly in order to accomidate the motor. I got the stuff off a 91 integra, but does that matter on which model I get the kit for? Everything else stayed the same. What do I get?
Old Oct 17, 2002 | 11:37 PM
guttedEF's Avatar
Default Re: which camber kit do I get?? (ZERO COOL)
If you get the camber kit that replaces the bushings where the upper control arm bolts to the frame, they'll work for both cars. The kit is universal for almost all Honda's..
Old Oct 18, 2002 | 03:43 AM
keithv's Avatar
Default Re: which camber kit do I get?? (guttedEF)
do you know you need a camber kit? supposedly the integra spindles give you positive camber. get an alignment if you haven't done so.
jdmeg6honda
Suspension & Brakes
Apr 16, 2011 10:25 AM
wwong510
Feb 13, 2007 11:11 PM
lsvtec_DA
Feb 25, 2004 09:59 PM
clutch33
Oct 29, 2003 04:54 PM
Blu5GLude
Nov 11, 2002 05:37 PM
