SiR cluster install
Old Oct 17, 2002 | 04:17 PM
EF_LSVtec's Avatar
Default SiR cluster install
It took me 3 hours to wire the sucker in and it works fine I used an
ECU pin tool and transfered each connector one by one. Just matched colored wires as the instruction says. I was guessing on how to install the electronic VSS, there were 3 wires black (ground), orange (lead), yellow (switched power), is this correct? Anyway, speedo works but check engine light comes on when slowing down. I couldnt have possibly interchanged the lead and power wire or else it wouldnt work...any ideas?
Old Oct 17, 2002 | 04:46 PM
bryant's Avatar
Default Re: SiR cluster install (EF_LSVtec)
here is a site: http://www.jdmfan.com/technical/cosmetic/sir_cluster/
Old Oct 17, 2002 | 05:06 PM
EF_LSVtec's Avatar
Default Re: SiR cluster install (CR-X)
Thanks but thats the same install instructions I have.
Old Oct 18, 2002 | 02:20 PM
crxjdmsir's Avatar
What's the code its throwing? I'll look through my notes to see if I find anything. Also what car did you get the VSS from?
Old Oct 18, 2002 | 03:42 PM
CRXB16aJDM's Avatar
New User
I used a prelude vss so the wire configuration was different from civics. Took me 3 trys til I got the configuration right but there's only 3 wires and 3 spots, hehe. Oh yeh, you gotta tap the speedo signal wire back to the ecu so your vtec can kick in. Your vss should have power, ground, and speedo signal, NOT switched power to cluster like you said. Your speedometer works?? than you wired it up right. Check what code it's shooting first.
Old Oct 18, 2002 | 06:43 PM
EF_LSVtec's Avatar
Default Re: SiR cluster install (CRXB16aJDM)
A reset on the ECU actually did the trick...Apparently, the ECU wasnt recognizing the new electronic signal from the VSS...Anyway, now I found a new problem...hehehe...I'll post a new thread.
Old Mar 11, 2003 | 07:22 PM
B6teen's Avatar
so u run the speed sensor signal wire from the sensor to the gauge and then to the ecu?
Old Mar 11, 2003 | 08:13 PM
EF_LSVtec's Avatar
Default Re: SiR cluster install (turborex)
i guess someone's been digging up threads from the past and bringing em back to life...
Old Mar 11, 2003 | 09:54 PM
EG8R's Avatar
lol Looks like it
Braco11
11
Mar 31, 2007 05:51 PM
USDMSiR
15
Aug 31, 2006 02:07 PM
EF8IGHT
Feb 14, 2006 09:11 AM
EF_LSVtec
Oct 29, 2002 01:36 PM
