Integra LS.. keeps draining my battery
Old Oct 13, 2012 | 10:05 AM
ALLDAY-24's Avatar
Default Integra LS.. keeps draining my battery
My car keeps draining my battery. The car drives fine when I start it and take off the negative from the battery so I know its not my alternator. But I just replaced the battery and it is still doing the same thing. It would start but not fully drive it would lagg until I take off the negative then it'll run good again. What is my problem?
Old Oct 13, 2012 | 05:53 PM
BC2003UGA's Avatar
Default Re: Integra LS.. keeps draining my battery
bad ground. high mileage cars can have severely corroded grounds, broken grounds, or i've even seen them completely removed by previous owners for some reason. check and replace all your grounds. get some good quality coated battery/amp power cable and re-loom all your grounds, hell add some while you're add it.
Old Oct 14, 2012 | 09:56 AM
mediajunkie420's Avatar
bad grounds and you may have something like ur glove box likt staying on or something
ALLDAY-24
Dec 12, 2012 01:07 PM
poptik
Jul 20, 2011 10:59 AM
fastrider213
Sep 19, 2009 11:53 AM
dianam321
Oct 28, 2008 05:24 AM
Pooby88
Jul 31, 2006 06:38 AM
