Will 205/50r17 fit a 1990 Honda civic hatchback hatchback?
Old Oct 12, 2012 | 09:40 PM
Alec Josephs's Avatar
Default Will 205/50r17 fit a 1990 Honda civic hatchback hatchback?
I'm 16 and new to the car world and I was wondering if anyone knew? I found some sweet racing rims that have the same bolt pattern and centre bore size for cheap but they are 205's so I wanted to know if I could manage to use these on my ride? Thanks
- Alec
Old Oct 12, 2012 | 10:20 PM
toyomatt84's Avatar
Sanji
Default Re: Will 205/50r17 fit a 1990 Honda civic hatchback hatchback?
They're not even going to come close to fitting. Those tires are 11.89% oversized for the car. At most, you shouldn't surpass 3% in either direction.
Realistically, you're not going to safely fit 17's on a comfortable tire size.
Old Oct 13, 2012 | 03:07 PM
Dang.. What do you recon will be the biggest I could fit on?
Old Oct 14, 2012 | 12:32 AM
toyomatt84's Avatar
Sanji
Biggest in what dimension? Height, width, or a combination of both?
I'd recommend looking at the FAQ's, as it explains tire sizing rather thoroughly. It also provides good tire size calculators to help you sort out the proper tire size for your application.
Old Oct 15, 2012 | 04:02 PM
A combination of both i suppose.
Old Oct 15, 2012 | 08:32 PM
toyomatt84's Avatar
Sanji
What's the goal here? Are you looking for better traction? Is it an aesthetic thing, and you want larger/wider wheels?
Old Oct 17, 2012 | 05:28 PM
macDelli's Avatar
I'd slap a 15" wheel on with a 195/50 or 205/50 tire. Best for look and comfort on that small of a car.
cguy82
Oct 1, 2017 07:02 PM
Phailzilla
Jul 19, 2013 06:08 PM
Hondacivic90ed
Nov 12, 2007 06:45 AM
Punk8oy81
Sep 10, 2007 07:14 AM
mustninty
Apr 22, 2005 08:50 AM
