Car stumbles in low rpm Help Please
Old Oct 12, 2012 | 08:37 PM
Infamous war's Avatar
Default Car stumbles in low rpm Help Please
First off I have 99-00 civic si turbo. The car stumbles in low rpm 1st and 2nd gear the car starts to buck. It also has no throttle response sometimes then it kicks in. I just changed tpsb2 days ago and still having the issue. Could it still be tps?
Old Oct 13, 2012 | 12:01 AM
holmesnmanny's Avatar
Default Re: Car stumbles in low rpm Help Please
I assume you're running a tuned ecu. Is your knock sensor disabled ?
Old Oct 13, 2012 | 03:20 AM
I haven't hooked up laptop yet but it should be. I had it tuned by Slowmotion here in Ohio
Old Oct 13, 2012 | 10:57 PM
Did you calibrate the TPS or just throw it on ? You should know you need to calibrate it properly to .45 - .50 closed and 4.5 wide open.
Old Oct 14, 2012 | 04:13 AM
Yea man in process of re hooking it up. I think my buddy didnt sit the tap In the tb like your suppose to either
Old Oct 14, 2012 | 11:09 AM
Ok fixed tps and don't have the bucking problem. But now I'm having problems of with warm startups being 19-20 a/f. I was reading it could maybe be the iat.
Any help would be awesome
Thanks for the info before too.
Old Oct 17, 2012 | 01:13 AM
This could be ECT sensor too.
hydell3
Jul 26, 2014 07:41 AM
deucedeuceEK
Apr 27, 2007 02:39 PM
actionanh
Nov 19, 2006 11:36 PM
TeknikDC2
Mar 6, 2005 06:30 PM
stizzit
Jan 24, 2002 08:30 AM
