600hp complete dropout
time to let it go. under 300 miles on the whole setup. local pickup only since i doubt anyone wants to ship. produced 608whp at 34.5 psi c16 with bbg installed and 440whp on pump gas. this will come complete and ready to roll.
ENGINE MODS:
83mm golden eagle oringed sleeved gsr block 1500
crower billet rods 600
cp 9.5 pistons 400
arp headstuds 100
2001 type r head 500
skunk 2 valvesprings 200
skunk 2 Retainers 200
stock r valves and port
golden eagle intake manifold 500
bdl 68mm throttle body 200
str fuel rail 100
paxton regulator 150
Gates racing timing belt 150
O.e oil pump,water pump,tensioner 200
Golden eagle oilcap and dipstick 100
Ati harmonic balancer 200
Competition clutch twin disk clutch 1300
gsr transmission w/ gearspeed carbon syncros 600
Quaife lsd 600
2001 type r camshafts 350
Golden eagle cam gears 150
Custom monster can overflow
Aluminum dual core radiator with Fal slimfan 100
Omni power quikclutch clutch master cylinder100
obx radiator hoses80
jhpusa rest of the hoses in purple 100
Hassport motor mounts300
Jimfab solid torque mounts 125
Vented valve cover setup with moroso catchcan 100
TURBO SETUP:
SLS topmount t3 manifold with dumptube 800
SLS 3 inch downpipe 300
Precision 6266 billet .82 exhaust in the t3 frame 900
Tial purple mvr 44mm wastegate 380
Tial Q purple bov 300
Goautoworks 2.5 charge piping hot/cold side 400
Garret intercooler 200
All tbolt clamps of course.
Walbro 400 pump 180
ID's 1000cc injectors 450
MSD 7aL ignition box with hvc2 coil 300
Omni power 4 bar map sensor 100
Thermal r&d 3 inch exhaust 600
-6 feed line 300
without any installation or assembly or tune.. your at 14000 in parts.
tune1800
priced at 10,000. this may sound like a lot but i promise if you tryed to build the same thing itll cost you more and give you a lot more of a headache. Ive got 1800 dollars in just the tuning itself. was tuned at tdc in mobile by tampa mike.
this is a drop in 10 second swap guaranteed.
part out prices:
Complete longblock with intake manifold and twin disk clutch. 5500
turbo kit, complete down to the ignition system, injectors,pump and feed line and tune. bolt on power. 3500
gsr trans with quaife and gearspeed carbon syncros 1000
hassport motor mounts 240
mak eoffer on rest. wont sell anything until longblock sells.
ENGINE MODS:
cp 9.5 pistons 400
arp headstuds 100
str fuel rail 100
Quaife lsd 600
TURBO SETUP:
Walbro 400 pump 180
-6 feed line 300
tune1800
part out prices:
if longblock gets sold.. itll go like this. complete turbo kit, trans, clutch ect. i will not part the turbo kit out since its already tuned.
bump part out prices. longblock price may seem high but it comes with an almost new twin disk , geintake manifold, ati dampner, all of it.
PRO1
Jan 25, 2012 08:27 AM
HiBoost Whiteboi
Feb 9, 2009 01:56 PM
Playero713
Dec 22, 2004 10:21 AM
