BMW 318IS 91' 5SPD Alpine White
Vehicle: BMW 318is 1991
Miles: 161,XXX
Price: $3,800
Title Status: In Hand Clean
Contact: Call/Text:786 953 3727
Vehicle Description: BMW 318IS 1991 Alpine White/Blue Interior
161,XXX miles.
5 Speed with 4:10 Diff.
Titile In Hand.
Fk Full Coilovers with Ground Control Camber Plates.
Basically bought the car just how it is on October 2011.Have driven it DAILY since. Got the car with 146K miles. Car has NEVER left me stranded, very Reliable. Since day one I've used 93 Premium Gas. Overall interior is nice. Dash has no cracks, door panels have no rips, carpet has seen better days.
Update: Rear right calipar is locking up. Changed pads thinking pressing it back would of fixed it. But no. Obiviously will deduct repairs off price.
Things I've done to the car:
Changed Oil every 3000 Miles.
New Air Vacuum/ICV/Intake hoses. (car came with all these cracked)
Fresh Radiator Fluid.
New Spark Plugs.
New Fuel Filter.
New Front Calipers,Rotors,Pads and Brake Lines.
Fresh Brake Fluid.
New Falken 512's 195/60
New no name Cat and Muffler(car came with a loud fugly fart can)
Front I Lip(didn't have any)
Sony CD player with AUX.
New Pioneer Speakers all four corners(car came with blown stock ones)
Keep in mind I changed all this ^ within 3-4 months of getting the car.
The Bad(how i got the car)
Front GC top hats make a popping/clunking sound when you turn the wheel only when your at a stand still or going under 5mph. Ive looked under and spring moves has you turn the wheel, was told that GC top hats aren't compatible with fk coilovers so new top hats would fix that problem.
No A/C. Previous owner told me it was missing the belt but it all works.
Driver seat needs to be reupholstered.
Slight knock coming from the back at times.
Rust. Under the rear left jack point, took hook area, under the kidneys, a couple spots along the windshield strip,rear license plate light area, front fender arches. Ever since i got the car I occasionally spray down the areas with anti rust spray can and keep the areas taped down. Hasn't gotten any worse. See Pictures.
Door locks dont work. I use the trunk key hole to open and lock the doors.
Also included:
NEW
Akata Spacers
Two 12mm 4x100
Two 5mm 4x10"
NEW
Hubcentric Rings 57.1 to 60.1
NEW
Tuner Lug Bolts with key
PRICE IS NEGOTIABLE!
Photos:
Interior:
Rust Areas:
Miles: 161,XXX
Price: $3,800
161,XXX miles.
Titile In Hand.
New Spark Plugs.
New Fuel Filter.
Fresh Brake Fluid.
Also included:
NEW
Akata Spacers
Two 12mm 4x100
Two 5mm 4x10"
NEW
NEW
Photos:
Interior:
Rust Areas:
TurboT
Jul 6, 2004 08:11 AM
naturalvx
Jul 29, 2003 08:08 AM
