no dash light on auto to manual swap
Old Oct 12, 2012 | 03:46 PM
215aPHILLYated's Avatar
Default no dash light on auto to manual swap
So I was rapping up my swap an the thread I was working off of said splice the green/white wire were the auto shifter use to be to the black wire. So I took the old shifter that was still plugged in an cut all the wires I get a spark an all my dash lights go out except the battery light. Anyone ever have this problem? I know I know I shouldn't be cutting wires while I have power to the car but hey... I have pics of it if nobody knows what im talking about any help would be appreciated.
I know the reverse lights are wired in there but isn't there one that goes to ecu?
Old Oct 12, 2012 | 07:19 PM
Axatax's Avatar
Default Re: no dash light on auto to manual swap
Sorry to say the wiring instructions in that thread are incorrect, and will cause the short you mentioned (you've wired your park light indicator into your starter wire).
Someone fries their dashboard on a weekly basis using those instructions but that thread won't go away.
Here is the proper way it is done:
https://honda-tech.com/forums/showth...ghlight=Axatax
Old Oct 12, 2012 | 10:19 PM
Thanks bro normally try to avoid how to's like that but I was in a jam. So what did I blow an how do I fix it checked all fuses under dash and Hood.
Cap'N Chronic
Mar 22, 2012 07:58 PM
ant$missShift
Jul 7, 2008 08:50 AM
jea_hood2k8
Mar 31, 2008 04:19 PM
GapxGuy
Feb 9, 2004 04:25 PM
devonic
Oct 16, 2003 04:06 AM
