swapping b16 gears into a gsr trans
So my gsr trans has the common third gear grind and was wondering how hard is it to swap hydro b16 gears into a hydro gsr trans? Can I put just the b16 gears in my gsr trans or is there other parts that are needed?
Unless you had a good donor B16 gear stack to use, it is gonna be expensive and not worth the cost to switch over to B16 gears.
You would be better off buying a Type R transmission in good condition at that point.
All the gears are a straight swap except for the mainshaft which will need to be shimmed. Keep the GSR FD (ring gear and countershaft).
Decided I'm going to fix my third gear grind and buy carbon synchros and while I'm in there install a jdm 4.7 final drive
Jintegragsr97
Transmission & Drivetrain
Sep 10, 2009 09:18 PM
