Motor mounts for RHD EF7 (dohc zc) To drop in a d16?
Hey guys. I have a Jdm Crx SI. Comes factory with a dohc zc, rhd. The dohc zc is about to be pulled soon and I want to swap in a D16a6 for boost.
Motor mounts I am not quite sure where I can turn to for a RHD chassis
Will my OEM Zc mounts bolt onto the USDM d16a6 and not even require buying anything custom??
Or is there a specific motor mount design to put a motor in a RHD chassis?
Thanks for any help
Thanks for any help
Considering a DOHC ZC will bolt up using stock mounts in a USDM 88-91 Civic I'd be willing to bet it goes both ways.
So you think aftermarket oem style replacements like Hasport or Innovative would work just fine.
Im also considering just putting just nserts in these stock mounts I have if they actually will work with dropping in a d16
I eliminated the front mount so I definitely need to do something
It would make perfect sense that they should be compatible. But without that front mount, I would highly recommend some reinforcement if you want to push more power.
That would be great. I am probably going to try and source a billet aluminum set of factory replacement mounts. I just like the look of them and if Im gonna buy new mounts why not go billet.
But Im also thrifty and may just fill the stock mounts
JapJunkie
Aug 4, 2004 10:17 AM
Import Tuna
Jul 6, 2004 06:19 AM
