Transmission & Drivetrain Gearboxes, Differentials, Clutches
Swapped B16a Tranny id?
Old Oct 11, 2012 | 07:16 AM
prb4t's Avatar
Default Swapped B16a Tranny id?
I recently purchased a '64 MINI with a B16 swap. I am trying to identify the transmission (S80, Y21, etc.). The barcode sticker on the tranny is missing. Is there another way to simply identify what transmission I have? Want to move to a longer final drive and need to know what I got. Sorry for the newb question.
Thanks
Old Oct 11, 2012 | 07:27 AM
parts@synchrotech's Avatar
Default Re: Swapped B16a Tranny id?
If you are going to swap the final drive. You will need to open the trans of course. Perfect time to do a tooth count and get a positive ID on what transmission you have. Get to work!
Post up your findings and we will help you ID what you got. If it is the original hydro trans from the swap it will have a 4.40 final drive.
Old Oct 11, 2012 | 07:39 AM
prb4t's Avatar
I was hoping to ID without taking it apart yet. I have to order a 3.42:1 (or maybe 3.7:1) from the UK and it takes 8-12 weeks. I need to know what tranny type I have to order. Was hoping there was some stamping # somewhere, or perhaps something visual I could use to figure it out.
Sounds like without the barcode I have to take it apart?
Old Oct 11, 2012 | 07:44 AM
You have no prior history on the trans and what may have been done to it. So the best way to know is by opening it. Especially since you are special ordering a part from the UK. Would not risk it. Your choice.
Old Oct 11, 2012 | 08:00 AM
prb4t's Avatar
Good point. Guess that's the best approach. Do you or do you know of any US providers of a 3.42 FD? Everything I have seen is 4.05 as the longest.
Old Oct 11, 2012 | 08:17 AM
Always best to be 100% sure. The longest we carry is the 4.0
Old Oct 11, 2012 | 08:26 AM
prb4t's Avatar
Looks like I got my weekend project. Thanks!
Old Oct 11, 2012 | 11:19 AM
Just finished this up...This will help a bit:
https://honda-tech.com/forums/transmission-drivetrain-127/tech-tip-b-series-final-drive-identification-3095354/
notburton06
Feb 3, 2007 07:58 PM
The Rob
May 13, 2002 07:06 PM
Ltech
Jan 29, 2002 08:02 PM
blykins
Dec 15, 2001 06:10 PM
