94 accord , need advice..
Old Oct 11, 2012 | 05:30 AM
Tgang94's Avatar
Default 94 accord , need advice..
My car for some reason when istart it , it goes up and down on te rpms . Like 2000 rpm down to 1500rpms , and does that back and forth.
Old Oct 11, 2012 | 08:38 PM
maystg's Avatar
Default Re: 94 accord , need advice..
Have you done anywork on the cooling system? I just replaced my timing belt and water pump.and it did that until I bled the cooling system.
Old Oct 11, 2012 | 08:55 PM
94accordhswaped's Avatar
The idle air control module could be dirty or it could be low on coolant
Old Oct 11, 2012 | 10:54 PM
holmesnmanny's Avatar
Warm the car completely up and then take off the fitv and tighten the plastic down until it bottoms out. It's important to do this when the car is warmed up and not when it's cold. There's a sticky in the faq's for the "fitv" just look.
Old Oct 12, 2012 | 06:29 AM
CD5Beneficial's Avatar
Yeah sounds like you need a good cleaning on you're FITV (Fast idle thermal valve) and IACV (Idle air control valve) Both will be located on the throttle body and are fairly easy to clean with minimal tools required.
My car had the same problem yesterday literally, I popped my intake off & gave both a good cleaning. Aswell as gave my throttle body a good scrubbin and my idle is now smooth as butter.
Old Oct 15, 2012 | 12:27 AM
Tgang94's Avatar
So how do i do this ? Im nt good with cars at all .
Old Oct 15, 2012 | 05:49 AM
Its located right beneath your're throttle body. You must remove you're air intake and theres like 3 bolts remove it, take the FITV apart and spray it with throttle body cleaner/carb && choke cleaner, put it back on and you should be good.
Old Oct 15, 2012 | 05:55 AM
eamonn's Avatar
Iacv valve same thing is wrong with my ep3 seemingly it happens to alot of them
Old Oct 19, 2012 | 08:00 AM
Tgang94's Avatar
I guess i had a clog in my cooling system , so i had someone flush it , and it still does te same problem. Only when its cold though
BobLoblaw
Jul 20, 2019 09:11 AM
J.B.Motorwerks2
Aug 10, 2013 05:29 PM
ronqqq
Jan 18, 2007 11:38 AM
buh
Oct 5, 2004 09:19 PM
