Spring Pad
In progress of building a ChumpCar.
Just cut 2 coils off the front springs and noticed the top perch has a removable pad. I assume it is only there to reduce rattle. Can this thing be safely pulled out? I guess removing it only adding maybe .25"~.5" drop and ever so slightly increasing gross spring rate.
As of now the springs sit securely within the perches even under full droop.
Just cut 2 coils off the front springs and noticed the top perch has a removable pad. I assume it is only there to reduce rattle. Can this thing be safely pulled out? I guess removing it only adding maybe .25"~.5" drop and ever so slightly increasing gross spring rate.As of now the springs sit securely within the perches even under full droop.
Naturally Aspirated
Sep 21, 2004 06:23 PM
